Building a Mk.3 front wheel
I want to rebuild my wheels with stainless spokes and rims, but I am getting a lot of conflicting information when I research spoke patterns, offset, gauge, length and bend.
I believe there is four spoke lengths, two gauges and 80 & 90 deg. bends.
When I look at the various wheel component suppliers, am I going get this?
Are the rim suppliers going to have the holes in the correct place?
Unfortunately, my original wheel appears to have been tampered with, the rim is not in the centre of the fork legs, so it's not much help!
I'm quite confident at having a go at building my own wheels. I have done many bicycle wheels with two and three cross as well as radial patterns. I understand that the spokes on the Commando disk side are near vertical. This is common to a lot of bicycle wheels to accommodate the very wide gear cassettes found on most modern bikes these days.
I have a good quality wheel jig and all the required measuring tools to do the job as well as a lathe in case i need to turn any spacers to fit the hubs to the jig.
And if it all goes pear shaped (literally) i can always go to a wheel builder who has Commando experience.
Any advice would be greatly appreciated.
I wouldn't know where to start building a wheel from scratch but I can recommend Central Wheel https://central-wheel.co.uk/ in Birmingham who will supply you with a correctly drilled rim and matching spokes for you to build the wheel yourself. And, if you ask nicely, they'll give you the offset distance and spoke tensions.
Also, consider going a little wider than original; 2.15 or 2.50 front, 2.50 or 2.75 rear. And 18" for the rear.
I have an original Mk3 front lying around that I can measure if you let me know what reference points to use.
Thanks for your reply Stan.
My existing wheel rim is 6mm closer to the fork leg away from the disk, surely it should be central?
By measuring a line from the hub to the rim then adding 3mm will give me a the correct offset for building the wheel.
I prefer to keep the original 19" wheel, and I have a pair of almost new TT100's.
wasn't sure about Central wheel, read mixed reviews, I thought Devon might be a better option?
The stainless rims and spokes for my Mk3 were supplied by Devon Rim Co. and my wheel builder didn't have any issues with the parts.  He builds and races sidecars and is very experienced at building his own wheels.
You're right about one set of spokes on the front wheel being almost vertical which means the tension is high to get the rim in the correct place.  So much so, that one spoke broke after lacing and the free end hit his garage ceiling!  Devon Rim supplied a new spoke free of charge.
This was done in 2013 and the rims are still excellent.
I am a complete amateur in wheel building but have just rebuilt my mk3 front wheel using the original rim rechromed.
The steps I took was to:
1. Note which side the rim was facing and location of valve to hub position.
2. Photographed the spoke lacing positions and also drew them on a cardboard template noting where every spoke went inside and outside.
3. For the offset I had a flat square board.with holes in the middle to mount on the hub with the disc removed, then simply measured the distance all round from the rim edge to the board surface.
Rebuilding was just using the notes above especially note 3.
Once the offset was done I then put the wheel in a jig to true it up.
As you already know how rebuild wheels it all depends if you have the confidence in yourself to do it. ?
Graham
Graham,
How did you find your rims after rechroming?
I had my Mk3 Dunlop rims rechromed by a well established classic car and bike plater, but now that I have finally got to the rebuilding stage, I am concerned that the nipples seem looser in their piercing ones than previously, being a somewhat  rattly fit, which they weren't when removed.  I am suspicious that the polishing process has taken too much material from the top edge off the cones, increasing the hole diameter (and potentially the cone wall thickness).  I guess this is one of the risks with rechroming rims, and I may have learned an expensive lesson.
Go for it Peter!
I recently rebuilt the front wheel of my Velocette, my first ever, and it was very satisfying to do. I'm looking forward to replacing my own MK3 rims in due course, and have done a little research.
An important point is to take your time - don't rush it.
Norman White describes the process in detail in his Commando Restoration book, and I recommend you get hold/borrow a copy.   There's lots of photo's too.
He also includes factory offset figures which is handy, and I would recommend you borrow an OE front wheel to confirm this for yourself, as well as for copying the spoke pattern when you do it.  It does seem that other spoke patterns are possible, but are not advised?
What you want is the distance from the outside of the OE WM2 Dunlop/Jones rim to the disk mounting face on the hub.  Should you decide to fit a wider rim then the new offset figure will be the OE offset figure plus half the difference in the additional external width of your new rim.  Avon list the appropriate rim sizes for their different tyre sizes - it's a bit of an eye-opener.
Clearly, the rim drilling is handed, and I will be demanding that any supplier indicates which way round the rim goes.
I'm not sure that it is realistic to expect either CWC or Devon to accurately bend the spokes other than at 90' degrees, and if so, do wonder if making a small jig for making minor adjustments might be worthwhile??  Another thought might be to have a word with Doug Richardson, who originally set up Devon and now works as an independent wheel-builder nearby?  Or some other wheel-builder?  Then there's the question of spoke gauges along with rim drilling.  Please let us know?
What I did find difficult was trimming the spokes neatly after everything was built-up and trued - what do others do?
Hi James, Yes, I have Norman White's book and I have also downloaded Vintage Bike magazine's excellent article on building a Commando front disc wheel. The first thing I did before stripping the wheel was measure the offset. The rim was actually 6mm off centre, so I was able to adjust my reference point measure from the hub by 3mm to get the rim central to the fork legs. It looks like the last person to adjust the spokes didn't like how vertical the disk side spokes were sitting, had he put the rim central, they would have been nearer vertical.
when I stripped the wheel, it had two gauges of spokes, four different lengths and three different head angles.
I have spoken to Shaun at the Devon wheel Co. and he confirmed that that is what they supply. I'm going to go for the highly polished stainless rims and stick with the original size.
Shaun also told me that the rims are marked in such a way to help with the lacing.
I took loads of photos of my wheel before stripping it and I'll compare these with the pictures in the various publications to ensure I'm heading in the right direction.
Shaun was very helpful and familiar with the Commando wheel, I'm sure if I run into difficulties, i can give him a call.
I slso bought Chris Rooke's book. He describes restoring his Mk.3, which is what I have, and find it an excellent read.
I have built a lot of bicycle wheels that have near vertical spokes on the gear side, so I'm aware of the challenges.
One interesting point, I asked Shaun if I should invest in a spoke torque wrench? He said no, do it by feel.
It should be an "interesting" build!
In reply to by peter_finlay
"when I stripped the wheel, it had two gauges of spokes, four different lengths and three different head angles.
I have spoken to Shaun at the Devon wheel Co. and he confirmed that that is what they supply"
Peter, my scepticism that all three spoke angles would be accurately supplied stems from a comment from someone on the Velo Forum in a similar situation, where all the bends were not precisely replicated - they were all simply supplied at 90 degrees.  This was from Devon too, but it was a few years ago.
I'd not come across that Vintage Bike article before, and hadn't thought about grinding down a screwdriver to assist nipple assembly, so thanks
https://vintagebikemagazine.com/technical-articles/lacing-norton-front-disc-rim-06-1951/
Incidentally, I don't like the strange tyre wear patterns that seem to quickly develop when using OE WM2 rear wheel rims combined with 100-90 x 19 tyres or larger, and suspect that it is caused by the size miss-match, so it will be at least a WM3 on the rear for me.  I do hope that Avon get their act back together by then.
I'm looking forward to following your progress
Hi Andrew.
My rechromed rim was OK as there was only slight rust to polish out, if a rim is too badly corroded it might not be worth doing as too much polishing can remove the original numbers which defeats the object of putting the original rim back on.
As mentioned above I took pictures before dismantling as there are 4 different spokes in fixed uniform pattern around the rim.
I also made sure the rim went back on in the same position and direction as it was removed. ?
As mentioned above when the rim was finished I smoothed the spoke ends using my dremel and a spot of silver paint to protect them.
You might wish to ask Devon as to which way round the rim needs to be in consideration of the disc side. They will tell you it is the side of the rim where the stampings are and which stamping relates to the disc side orientation.
I can't remember in my case as it was a number of years ago now but could take a look at the wheel to confirm if required.
Some things to note on the MK3 front wheel. Using stainless spokes will have no relation to the original spokes as stainless spokes usually tend to be a thicker gauge.
Tension - yes, the tension differs massively between the near vertical and the spokes controlling the offset, that does not mean that one set has very high tension, if it does you have not offset the wheel correctly prior to pulling it over to get the correct offset - check the tension on an original MK3 wheel, it might surprise you how little tension there is in the spokes. getting that initial offset is a real pain but worthwhile getting that stage correct.
The rim must be pierced to the correct Norton 40 hole pattern for disc wheel. Also, look on an original MK3 wheel you'll notice any lettering on the rim is on different side to that on a pre MK3 rim. The drawings and much online says the lettering should be on certain side, and even the drawings have this wrong - how can it be, as the spokes are not only different from one side to the other they are also laced in a different direction due to braking. If the manufacturer of the rim suggests that the lettering should be on one side then make sure they are fully aware that the rim is going to be used on a MK3, many just assume that the rim will be used as a 'Norton disc brake' not an issue but the piercings and the lettering may not follow convention as the rim needs to be spun 180 for MK3 lacing. You'll soon know when this is wrong as the spokes will be bend either in relation to the nipple or over a and adjacent spoke as they are tensioned up.
I have a pile of photos of original MK3 front wheels and even laced my own, if anyone wants photos then they are welcome.
Always buy the rim, spokes and nipples from the same supplier, do not mix and match.
After all the spokes and rims arrived from Devon, I got to work. I chose their highly polished stainless rims, just like chrome, very nice.
I'm glad I took a lot of photos of my original wheel before I stripped it, they were needed.
I marked up the four sizes of spokes with different colours of marker pen, then did the same to the matching spokes in the photos. That helped getting the lacing right, and not mixing up the different lengths.
After a few attempts, it became clear that both sets of inside spokes had to be laced first. Lacing the rest after that was straight forward.
I trued up the wheel first by using only the disc side spokes, making sure that the wheel was round and all the disc side spokes were at an even tension and quite tight. At this stage, the offset was more than required,  which was what I was hoping for.
I then got the slight wobble out of the rim by adjusting the non disk side spokes. Once happy with the trued wheel, I then checked the offset. It was easy to pull the rim to the correct position with the non disc side spokes, and they were at a nice tension.
The whole job was easier than I expected,  but I think the large number of pedal bike wheels I have built in the past helped.
Thanks to everyone for their help and suggestions. Back wheel next!
.. and I like the jig. Mine is the economy model made out of MDF (BSA A10 wheel):
wheel jig
It was OK on the A10 - the bike came with it fitted - but I didn't actually have the BSA that long although I liked it. I wouldn't fit one of those tyres intentionally unless I had a sidecar outfit....
Peter,
Check other MK3 front wheels, it looks like your original was not correct to use as a sample. The disc side inner spoke is key, it should be a trailing spoke.  If you need photos of original wheels I have plenty.
Thanks for this information Ashley, it's definitely a bugger after the work involved!
I'm assuming the wheel will not be as strong under braking?
i have just come across an article that says Norton used three different spoke patterns!
some photos that show me the correct pattern would be greatly appreciated, especially showing the rim nipple holes next to the valve hole. Any other tips would be greatly appreciated.
can you email them to me?
petefinlay@outlook.com
Many thanks.
Just spoke to the guys at the Devon wheel Co and sent them some photos.
they thought the wheel lacing was good with no problems.
can anyone clarify before I strip the wheel?
I bought an SS rim complete with spokes from Devon, the kit of parts had 4 different spoke configurations.
This on a '72 Combat. I cannot think of any reason this set up would be changed just because your disc is on the "wrong side" to mine!
I read somewhere that the factory wheel builders used to stamp on the spokes to get them to stand vertical in order to apply the correct offset then true up!
There are many sources on the web about wheel building the Commando disc front wheel all very interesting reading and baffling to boot. Bought the spoke wrench built the jigs tried numerous times determined to DIY it no chance. Took it to Joe Brown "simples".
I've just had a check on the spoke pattern on my 1975 mk3, I put everything back as it was originally. ie
The MC175 on the rim is on the disc side of the wheel.
Looking at the wheel from the right side non disc side of the wheel the spokes are in a pattern of four repeating starting from the valve. ie
Left to Right.
1. Spoke to outside of hub non disc side.
2. Spoke to inside of hub disc side.
3. Spoke to inside of hub non disc side.
4. Spoke to outside of hub disc side.
Graham
A very useful screenshot so thanks Graham.
Ashley suggested that "the disc side inner spoke is key, it should be a trailing spoke", but that doesn't appear to be the case with your wheel?  Surely they are leading spokes, and the same pattern as Peter has followed on his new wheel-build, or maybe my anorak is too tight?
Leading Spokes:
"These spokes are angled to lead in the direction of wheel rotation. They are under compression when power is applied, essentially pushing the rim forward"
Peter, my mistake, if you spin the wheel the inner spoke is in tension when the brake is applied, this is providing you put the disc on the LHS of the bike, and one of the reasons it is not wise to just simply swap a pre-MK3 wheel onto a MK3. The rear wheel it is case of the dominant force and that is considered the driving force and not the braking force.
The MK3 rear wheel is another strange one with the odd lacing pattern. We have a letter here between CWC and Norton dated around the mid 70's on what was the strongest pattern to use, and that is why the lacing on the rear is like no other.
Does much of the above matter, not really as many have swapped fronts and got away with it and the rears have been swapped out for alloy rims which have a more conventional lacing pattern.
MK3 Front
Just to be sure then, I take this to mean that on the MK3 only, the front wheel disc side inner spoke is a leading spoke, and on the earlier Commando's with the disc on the right, it's a trailing spoke.  The general principle makes sense to me.
MK3 Rear
Turning (!)  to the MK3 disc rear wheel,  I don't understand why changing from a chrome rim to an alloy one (as I'm planning to do) involves a change in spoke pattern.  I propose to simply follow the old OE pattern, and am grateful that I have an original that has not been re-spoked.
My understanding was that at some point in time, CWC adopted a replacement rear spoke pattern that was different to that of the factory - though whether they ever reverted back, and if so after what period of time I've no idea. If it involved a different rim piercing pattern then this needs revealing.  But then again' I could simply be regurgitating bo--ox.
Peter,
I'll send photos shortly.
James,
Yes you the have the idea for the front, the MK3 rear is pierced for the odd spoke pattern that it has. Alloy rims are not pierced in the same pattern unless you ask for a blank rim to pierced to the MK3 rear pattern.
From the 1970's letter we have here CWC were not happy with a conventional type lacing pattern for the MK3 rear, the lacing we see to this day is what they suggested and it is a very strong pattern. The pattern you see on the rear is strong and would work on the front and there are many out there using the rear rim laced using the rear lacing pattern on the front as that was how CWC used to lace them upto a few years ago. However, Norton never used the same lacing pattern on the new bikes back in the 70S, as we often see. Norton used the same lacing pattern as the pre-MK3 but with some changes, spoke gauge and direction were changed to suit the change of the disc from one side to the other, some may have spotted that to do this the rim needs to be orientated correctly as well so be aware that the rule of lettering on a certain side does not apply. It soon becomes evident when this is wrong at the spokes will start to bend near the nipples when you start to tension the wheel, again often spotted and once you see it then it is very obvious, Phill Hannam pointed this out to me at bike meet meet we were once at, and it can still be seen to day, twice in the past year I have seen it.
On the Commando disc front wheel over the years they used 3 different lacing patterns, though one I have never seen, many different gauge spokes, some MK3 used different gauges. There were also 3 different hubs, but again the later one didn't make into production we believe.
