1966 Jubilee wiring harness
Hi, could anyone tell me if there's any pre-made harnesses out there to buy with the WIPAC connectors to lights and ignition?
Thanks.
... may have something to suit although the original switch connectors aren't the best. I believe he suggests doing away with them and soldering flying leads to the terminals. I found that 4.8mm Lucar (spade) connectors fitted well.
I replaced the original Wipac colours with standard Lucas.
The biggest problem with ORIGINAL Wipac loom would be the 6V. The original 6V system had a wire resistor built in the loom. I have seen several dangerous attempts to re make this. DO NOT DO IT. I can supply a resistor for this job, but it is best to retain the 2 X6V WIPAC coils and fit electronic ignition and 12V. Forget original 6V.
I can also supply a wiring KIT.  Details of the 12V and advises for the Wipac switches are on my web site.   aoservices.co.uk
