Navigator fitting oil filter
Can someone please advice on fitting a cartridge oil filter for the engine oil, I think it should go on the return line? also were is the best place for it to be fitted on the frame?
Thanks, Steven
There’s a few threads on this if the search function can find them! Yes it goes on the return line I mounted mine on the central channel.
dan
question asked by someone called Dan Field.
https://www.nortonownersclub.org/node/7367
