indicators
Hello. thinking of fitting some indicators to my bike. will fit the fronts onto the headlamp bolts on the shell. but just wondered what would be the best position on the rear. in the photo attached there are some positions marked just wondered if someone could help to choose the best position.
Barry
indicators-jpg
Thanks for that Bob. nice bike you've got there . i think that 4 is good place to fit them. i am thinking of having a traditional rounded type that have the long mounting extensions.
Barry
I suspect pos 4 will be subject to a lot of vibration. Personally I think pos 2 would be firmer. I think pos 1 could end up being shielded when viewed from a certain angle.
BTW - where did you get the rack?
George
thanks for that George, i know what you mean, as it is the mudguard is not original one but it is a hefty sort over 2mm thick so it handles the vibration ok. i mounted it a bit firmer towards the front bracket and centre when i had to welded some metal to it. the rack was originally from RGM but altered over time.
Barry
