As I have not yet invested in a thread measurer (correct expression?) could anyone tell me the thread pitch/size on the boss outlet for the oil tank on a '55 ES2?
Many thanks for any help.
George
Hi George, I think that sh…
I haven't rushed out to c…
I haven't rushed out to check Ian but I'm sure the boss on the tank is more like 1/4". I think you may be thing of the whole unit. I'm after the little boss dimension.
George
The dimension given is for…
The dimension given is for the oil feed connection (the larger/outermost of the two, with the mesh filter) on a '56 tank. I think your '55 tank is a different shape but I was assuming the connections are the same size. I could have that wrong.
Cheers, Ian McD
No - I'm sure your right…
No - I'm sure your right Ian. But as far as I remember the "oil tank adaptor" is the whole unit with - as you say -a 1" connection, but it has a small spigot on it with a male thread into which the adaptor from the oil line connects. It's this small connector that I need to know the size of) apols for the English!!)
George
Hi George, The thread on t…
Hi George,
The thread on the oil filter outlet/pipe connection is 1/4" BSP. As you may know the 1/4" refers to the nominal bore size, not the actual diameter of the thread. This is the same size as the petrol taps and breather pipes on the drive side crankcase and the oil tank, also the oil tank return pipe. BSP fittings are still current and widely used, particularly on compressed air fittings, so should be easy to get in a selection of connections. Are you thinking of fitting a tap to this outlet?
Regards, Richard.
Well done Richard. That ti…
Well done Richard. That ties up with what I thought, but wasn't sure. yes. I'm idly playing with the idea of fitting a tap or - if possible - fitting a quick action drain cock to the sump plug?
George
I hadn't realised that th…
I hadn't realised that the spigot could be separated from the adaptor. Still learning!
Ian McD
Previously Ian MacDougall…
Ian McD
Hi Ian,
I guess you already know this part is all one piece, the descriptive wording doesn't always convey what we want to say!! Although having said that it would be possible to cut off the pipe fitting flush andcut a female thread so an oiltap could be screwed directly into it. You won't get many threads in the thickness, so it will need to be securely soldered together.
George,
An oil tap could catch you out if you don't have a fail-safe reminder, but a quick action drain-cock sounds like an accident waiting to happen??
Richard.
Previously richard_cornish…
Ian McD
Hi Ian,
George,
Richard.
hi george/ian,have a look…
hi george/ian,have a look at kingpin components,they have a new tap,1/4 and 3/8 bsp connections, with a wire which connects to the magneto cut out,the bike wont start with the tap closed,
Thanks Les, I'll follow t…
Thanks Les, I'll follow that up. Apols to Ian McD, it's my lack of descriptive power. I was trying to find what thread/size was needed to screw onto the small male boss on the outlet side of the larger composite connector that screws into the base of the oil tank, which Ian correctly noted is 1''. I now know the answer is 1/4" I can start sourcing some cut off taps although it's by no means certain I'll go down that route. Just fed up having to drain the sump every time I want to use the bike. I've currently left it with the drain plug out and a jug underneath. Just pour it back in, fit the plug then tog up and away!
George
Hi George. people seem to…
Hi George. people seem to make a lot of fuss about this sumping business. I just start the bike ('57 ES2) and it starts and runs fine. Yes, the oil tank level does fall a bit after a couple of weeks but it soon pumps back up and I notice no ill effects resulting from starting on a partially filled sump. The worst I have seen was after the snow last winter when I had left it for about 6 weeks but even then I only noticed a bit of exhaust smoke on starting which soon cleared.
One possible point is that the vendor told me that a Morgo oil pump was fitted. I don't know if that makes any difference but it could be a factor.
Cheers...........Chris
I would say it was a major…
I would say it was a major factor, Chris. The Norton oil pump is the bÃ?te noir when it comes to wet sumping. I was away for one week and then drained 500ml - about 1 pint - out of the sump. Presumably if left it two or three weeks the entire contents of the oil tank would end up in the sump!
George
A nice new steel-bodied (a…
A nice new steel-bodied (as per the twins - no more distorting monkey-metal) oil pump from Andover Norton will solve all of this, without the risks associated with taps or springs.
The new pump is over £…
The new pump is over £180 Richard against £80 odd for the tap and new mag end cap. I'd have to be convinced that the new pump really did stop wet-sumping at that price.
George
Oops. It's over £200…
Oops. It's over £200 for the pump - I omitted to add the VAT!
Fot what its worth.. my Do…
Fot what its worth.. my Dommie with cast steel pump wet sumps far quicker than my 16H.
No problem with neither th…
No problem with neither the ES2 nor the 16H. Sump content automatically goes out to the ground.
Anteriormente George Phill…
Anteriormente George Phillips escribiÃ?:
Ups. Es mÃ?s de £ 200 para la bomba - omità agregar el IVA!
DespuÃ?s de limpiar varia…
DespuÃ?s de limpiar varias veces el piso sucio con aceite, mÃ?s los enojos de mi esposa, logrÃ? un cierre perfecto con una electrovÃ?lvula en mi 16h.
Ver archivo.
Saludos
Attachments magneto-jpg- Log in to post comments
Probably sound advice!! Bu…
Probably sound advice!! But my Spanish is limited to asking for a table for two, ordering beer and a small meal! Can any one translate please?
George
I hope understand me (my e…
I hope understand me (my english is almost like your Spanish), but think that with the help of the Google translater, we can understand each other.
In my 16h managed to adapt a solenoid valve that when current (12Varrives, produced a displacement of an internal piston that allows the oil to drain to the engine.
When the engined is turned off it cuts off the current and a spring returns the pistonto seal against a rubber ring(o`rings). Can you the picture.
Greetings, Gerardo
Previously George Phillips…
George
George;little tip: Ifyou have googletranslate on asmartphone, selectthelanguage thentpress thecamera icon on thephone. Lookat the screenviayourphoneand itwilltranslate directly. Iuse and IPhonebutsure itworksonmostothers.
PS:you cando thesamewitha Menu
Previously Gerardo Zamparu…
I'd be worried that if the dynamo wasn't charging it would fail closed. Our bikes aren't famous for reliable electrical systems.........I hope understand me (my english is almost like your Spanish), but think that with the help of the Google translater, we can understand each other.
Greetings, Gerardo
I wonder where the power c…
I wonder where the power comes from, Gerardo. You must rely on the voltage from the dynamo. But then what? Does the solenoid draw power all the time, or does it use a latching relay? If it uses a relay, then how do you switch it off again? And as Ian says - isn't is taking a big risk? There are lots of stories on this message board about engines being damaged through not opening the valve, but are there any stories about damage caused by wet sumping?
Is there a way to arrange a cut out earth wire on a magneto for the singles - like the one on the twins? If so, it would be fairly simple to have a switch connected to the tap, so it closes to earth the magneto when the valve is closed.
ps I paste your Spanish straight into Google.
Gerrardo: Where did you pu…
Gerrardo:
Where did you purchase the solenoid oil valve?
Manufacturer's part number?
Previously michael_sulliva…
Previously michael_sullivan wrote:
Gerrardo:
Dear Michael: It is a valv…
Dear Michael:
It is a valve used for the passage of fuel ( in truck engines, I think Cummins). you can get it in your country, I think.
Attention, it took me several hours of work to adapt it, due to the little space, see the photo(magneto-jpg 578,1kb), analyze very well before buying it, they are for "12 V" .(My Norton has a theold MagDYno), which is 12V and 60W (at 1000 RPM it produces 35 W). Al its lights are led.
You must also use 20 W 50, multi- regulated oil, for better circulation.
Greetings, at your disposal.
Gerardo (disculpas por mi mal InglÃ?s)
Hi George, I think that should be thread gauge. For '56 the oil tank oulet boss is 1" 20tpi. Looking at thread tables the only match I can see for this size is Cycle which offers 2 pitches for 1" diameter, 20 & 26.
Cheers, Ian McD
