Rotary needs help
Hello,
my interpol2 is a being difficult, it ticks over lovely, and when stood will accelerate to high revs smoothly, but when ridden at low revs it hunts then accelerates fine to 4500 revs but no further this gives about 50mph and drops as it climbs hills. The effect seems like fuel restiction.
I've changed from ASBO exhausts to standard and set the carbs up as per the book after cleaning them, would the change of carbs require a different set up or is it a bit more basic, your thoughts and advise gratefully received.
BobP
Bob,
It sounds to me like an air leak, my Commander surged owing to the right hand induction tube leaking where the tube enters the rotor housing.
In any case I would suggest you post your question on the Rotary Owners Website, there are a number of very experienced rotary owners there who will be able to offer you much better advice than myself.
That said I am sure you will also receive very helpful advice from this excellent NOC forum as well.
Previously Tony Duffield wrote:
Bob,
Bob,
Tanks Tony,
Have been to the site and found my query answered, I,ve redone all the inlet joints greased the o rings to help seal them,now need the chance to test ride
Bob Presley
4500RPM should give you about 70 MPH depending on gearbox and gearwheel sprocket size. If you have one of those plastic in line fuel filters fitted they often distort with the heat and close up. There is a filter in the petrol tap so the inline filter is superfluous. Ensure you are getting adequate fuel flow by sucking on the vacuum pipe to the tap with the carb fuel pipe disconnected.
Hi All
thanks for your help and comments, I've been out for a ride and the resetting of the inlet joints has done the trick, it flew, first time I've really felt the bike perform and its great, roll on the summer lets get out there.
Bob Presley
