1929 Model 19 timing
Hi All,
I have just purchased a 1929 model 19 and wanted to check the engine data I have in an old Norton maintenance book.
1 Valve Timing inlet 5/16 BTDC and exhaust 5/16 ATDC
2 Ignition timing BTDC fully advanced 5/8
3 Tappet clearance Cold inlet/outlet .003
Can anybody tell the flywheel endfloat measurement.
Thanks in advance
Andy
Sorry, I can't answer your question. However, regarding ignition timing, remember that petrol, in the 20's & early 30's, was of a much lower octane rating than modern fuel ( probably the equivalent of 70 octane). You will probably have to experiment a little to get the best running. Hope I am not teaching you to suck eggs!
Previously Andrew Jarrett wrote:
Hi All,
Thanks in advance
Andy
.005" - .010" should be ok for crank end float
Hi All,
Thanks in advance
Andy
Andy,
My 1930 Norton Maintenance manual (and 1930 haycraft "Book of the Norton") lists the following data for a 588cc OHV:
Ex open: 7/8" (55-60 degrees) before bottom dead centre
Ex closes: 5/16" (25-30 deg) after top dead centre
In opens: 5/16" (25 - 30deg) before top dead centre
In closes: 1/2" (40 - 45 deg) after bottom dead centre
Tappet clearance: 0.003" on both inlet and exhaust
Ignition: 5/8" (35 - 40 deg) beore top dead centre fully advanced
(however with modern petrol I would be testing this and possibly slightly retarding ignition)
Flywheel end float: 0.005 - 0.008"
regards
