Hi all, i'm currently attempting to assemble my 1959 norton model 50 into it's cases. Quite frankly i'm ou of my comfort zone and petrified of causing more work for myself. I've got MP's CD and also the period maintenance manual. I've laid the alternator side case on a wooden frame (a stool!) and carefully inserted the crank into it from above. It'll go so far and then no more! I'm really wary of forcing it - ie hide mallet etc. I've seen on Mike's cd that the one he's demonstrating with is a simply drop/ twist and it's in?!
I've pulled the case off (it was tight) and had a look inside. What i can see is that the engineering firm that recently did some work for me (they loctited the bearings on the crank and case) appear to have fitted the spacer (with castelations in it) the opposite way (castelations down) to what mike suggests (castelations up).
My queries are:
1) how do i get the crank fitted into the case?
2) is the castelated spacer ok as is (ie the opposite way that Mike suggests)?
3) is 2 above causing the problem?
Any help would be greatly appreciated.
Nobody has dared stick their…
Thanks for the reply David. …
Thanks for the reply David. My present plan is to take it back to shop that did the work and query why they loctited the bearings in and put the spacer in the way in which they did.
Your description says (they…
Your description says (they loctited the bearings on the crank and case) Does that mean the inner race of the bearings is glued on the crank and the outer race glued in the case? What kind of bearings are you using? ball raced brgs or roller bearings? What work did you get the engineering people to do on this exactly? Were the bearing races loose in the case?
More info needed.
Hi Peter and thanks for your…
Hi Peter and thanks for your interest/ queries. In answer i took the crank and cases into the machine shop to have the little end replaced/ honed etc. I'd stripped it down as much as i felt comfortable doing. The cases weren't separating easily and i didn't want to damage things unnecessarily. When i collected they'd degreased and loctited both roller inner main bearings drive side outer main bearing. It seems that all had been spinning in the crank case and crank main shafts.
The bearings used are what was in there already - outer is a ball. inners (on crank) are rollers.
Nobody has dared stick their neck out on this one. It might be best to remove anything stuck together with Loctite and measure it all carefully. Most Loctite loses strength when hot - their website will probably confirm how hot - so the kitchen oven with a thermometer might be needed.
