1933 16h
 I have a dolls head gearbox with a number TNS 87697 will this be suitable for my 1933 16h
thanks
Hi David,
   I have not seen your gearbox, but I guess it is a WD 16H. All these gearboxes use the same fixing, so there should not be a problem. The 1933 2 main bearing engine uses an engine mounted shock absorber whereas the later shock absorber is in the clutch. You can use both of these together, but if you have not got the engine s/a you will need a sprocket with the off-set on the outer side for the correct chain alignment.
Richard, thank you for the information, I have a s/a fitted and I am waiting for my gearbox overhaul kit to arrive.
