I have brought my es2 out of the garage for the first time this year and she has wet sumped . I have been off the road for 30 years and not sure what to do before I start her up . Is it ok just to fire her up and let the oil in the sump burn away or should I do another method . I cannot remember what to do . I realise the question may be a bit naff but after 30 years off the road you lose the plot a bit. Any help much appreciated
If it's been sat in the g…
Slight disagreement, drain…
Slight disagreement, drain sump, and tank, and replace with fresh oil. After 30 years there are likely to be more problems, than just wet sumping. Best advice is to join your local branch, who will, no doubt, give help.
Fair comment, John, but I…
Fair comment, John, but I took it that it was John (Rogers) who had been off the road for 30 years, not his bike. G
If it's been sat in the garage for some time, John, it would be safer to drain the oil from the crankcase and return it to the oil tank. Otherwise you may blow seals and distribute oil all over the place. When (if?) she starts check that the oil is returning to the tank. George
