000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Frame Number
Good Evening,
I have been left some norton parts and one of the items is a frame, could someone please expalin what the B&M means at the end of the numbers.
Any help, my thanks in advance
Kind Regards
Steve
That's not the frame number, it's simply the lug casting number.
'M&B' is believed to be Mason & Burns of Walsall, the malleable iron foundry who produced the castings.
Hi Steve,
   Good info from Richard P. BTW, if you're not aware, the frame is a circa 1950 Model 7 Dominator.
Steven,
It's hard to tell from the photo but is the frame missing the front petrol tank mount casting where the frame number is usually stamped?
Hi Ian/Steve,
   Yes, it looks like the tank lug has been purposely removed which will be a problem if the frame needs to be registered. There might be a frame shop number elsewhere which was used around this time, but if not, it will be difficult.
Be careful!  The frame lug might have been removed to keep the frame being traced back to its rightful owner.
  Just a thought
Privacy Policy
