Afternoon. A lovely ride over the Blackdowns yesterday, but along the way lost one of the bolts holding the rear stand on (1947 M18). Can't see one on the shop ..... Might be wrong though. Any thoughts on where to get one, or what to ask for if i need to get one made up, gratefully received. Ta.
Depending on what you have…
Thanks Mike. You reckon ce…
Thanks Mike. You reckon centre stand and rear stand bolts (47 M18) might be the same thing? I'll take a closer look.
Previously Michael Rettie wrote:
Depending on what you have, search NOCParts for centre stand.
Philip, The 1948 parts boo…
Philip,
The 1948 parts book lists the Rear Stand Bolt as E3818, which probably won't help you much. However I think itmay bethe same as on WD 16Hs which was part no. 9613 and that was 7/16" x 1+ 5/16" x 20 tpi, only the end bit threaded to fit the tapped hole in the frame.A thinned locking not helps to keep it there - don't ask how I know !
The centre stand bolts on…
The centre stand bolts on my 1952 ES2 are 7/16" x 26 tpi although of course this may not be original....
Thanks Pete. Brilliant. I…
I also just bought a caliper gauge, which helps a lot!!
Russell Motors usually hae…
Russell Motors usually hae them, although with modern plating of course.
Thank you. I will try ther…
Thank you. I will try there as no luck elsewhere .....
