Help!
I have a 1955 norton es2 with a standard size piston fitted.i have been trying to get hold of the rings for it .Each set I have ordered so far the oil scraper ring has been to thick,I have measured it as 5/32 .I have been told the one I need is only 1/8 .Does anybody know where I can get hold of one of these
What make of piston is it?
There is no name on it,jus…
There is no name on it,just has stamped inside B199
On the top it has stamped 796-10/1 OT ?
Hi Mark, If possible look…
Hi Mark,
If possible look inside the piston from underneath and the manufacturers usually have their initials or logo cast on somewhere. It will be something like H&G, Hepworth, Heplex, AE etc. Another Norton quirk, if you have an original piston, is the thickness of the compression rings. Most other manufacturers used 1/16th (.0625") but Norton used .060" so you may want to check your new ones against the ones in the piston. Another thing to check is the radial depth (width) of the new rings.
Regards, Richard.
Previously mark_osborne wr…
Hi Mark
My 38 ES2 had this number on top of mine 796-11 OT (Std)
Underneath just showed another number something like 796-96
No manufacture stamp at all.
I had Cox & Turner make me a new set of rings.
The 1/8th oil ring usually…
The 1/8th oil ring usually is for 16h pistons and the 5/32nd for the ES2. The compression rings are the same for both as far as I remember.
Have you got a 16h piston fitted?
EnvÃo imagen de pistÃ?n…
EnvÃo imagen de pistÃ?n 16h marca (JP PISTONS-FWThornton & Son ltd).
Saludos Gerardo.
foto0080-jpg
