Pre-war knee pads
I am refurbishing the tank on my 1936 16H as what is left of some aged sealant in the rusty inside is breaking up and the whole thing needs sorting. Although externally the tank looks reasonable the bike came to me fitted with John Bull no.25 "pneumatic" knee grips as shown on the photo below. These are fitted to steel plates to give a screwless appearance and, because they are a different shape and longer than the correct Norton pads, a previous owner has redesigned the tank striping and logo position to suit these pads - well, sort of !
Having removed the John Bull pads and fitting plates I see there is a circular protrusion on each side of the tank of about 1?" diameter and about 3/16" deep, centered 2?" ahead of the screw holes. On one side the JB plate had been cutaway to fit around this protrusion. On the other side the centre of the protrusion has been fitted with a short threaded stud as an extra anchoring point for the JB plate.
These protrusions look like original fittings and because of the above must pre-date the fitting of the present JB knee pads. However I can't see what purpose they fulfil; indeed they would foul the fitting of Norton pads as they align with the front lip. The tank otherwise seems original matching the number on the factory record.
Before I remove these protrusions to fit Norton pads could anyone kindly suggest what they may be for.
tank-side-right-2-jpg
Aren't they the proprietary solder-fixing mounting bosses used in the vintage era, generally on soldered tanks ? for example this Model 25 :-
I've seen them for sale with NOS grips. In my opinion, they don't belong on your tank.
Hello,here is a photo of the tank with rubber to my 1932 Big 4. The rubber is hold with a single bolt and nothing more and the tank filler is on the left side of the tank. And I have the cirkulare mountings on my 1926 M18 where the square John Bull rubber is mounted.
Regards from Svein.
mms_img989921707-jpg
Thanks Richard/Svein, your explanations appreciated. I thought they looked like propriety items, albeit it would now seem from an earlierperiod and on a tank where they should not be.I have now desoldered them, photo attached of the pair cleaned up. If anyone can make use of them they are welcome to them.
1920s-knee-pad-fittings-jpg
