Plunger engine plates on ebay
Previously Dan Field wrote:
These any good to anyone?
http://www.ebay.co.uk/itm/Norton-engine-plates-for-plunger-frame-single-ES2-Model-50-19-/231981655083?hash=item36032f242b:g:8H8AAOSwMNxXYxgA
http://www.ebay.co.uk/itm/NORTON-PLUNGER-ES2-REAR-ENGINE-PLATE-LEFT-HAND-/381667835654?hash=item58dd2cff
Thank you Dan,
are these the same as your plates, that you said that you would trace around?
ive bought the triangular plate in black. And will bid on the others if they are correct, one of them as they are both from the right hand side.. I believe!
cheers, Ian.
Hi Ian,
Hope these plates are what you wan't and if they are; don't forget to let Ian R down under know you are fixed.
Hi Ian
My plates are the same as the plans you sent me, my problem was that I had used my plates as a template to make a pair of Aluminium plates, but they didn't fit! I was worried that the plates were wrong but a bit of filing and fettling had them fitting ok! I can take a picture of mine if it helps? I'm keeping mine as I hunt for bits to put it back into road trim.
I have a spare bare single plate if anyone needs one, but it's not original.
Dan
