Oil spray over rear wheel of 47 ES2
Hi Everyone,
Been fighting with an issue of oil spraying on the rear wheel of my '47 ES2. After riding the bike for 20 miles or so, Iam getting a fine mist of oil being sprayed on the drive side of the rear tire. Initially I thought it might be oil leaking out the bottom of the primary drive so I drained that and did a test ride with a dry primary. Same result. Now I am thinkiing it might be a gearbox leak, possibly behind the mainshaft sprocket. The bike was restored by someone else and I am not that familar with Nortons with pre-AMC gerboxes. Any ideas for the source of my leak? Thanks.
Tobin
Norton, in their wisdom, designed the crankcase breather to vent over the gearbox sprocket. This was a geat idea, no need to oil the rear chain. Unfortunately, depending on oil level, and how hard the bike was driven, it also lubricated the rear wheel!! A simple solution is to run a plastic tube, from the breather pipe to the rear mudguard, and let it blow out behind the bike. Slightly more ecologically friendly, is to run it into a small can. There are several more technical methods, but, in any case, you will have to remember to lubricate the chain manually.
Hi.
John's pretty much nailed it. The only thing I can add is thatthe sleeve (4th)gear has no oil seal on the upright gear box which adds to the problem. Fitting a bearing with a rubber 'shield' helps. There is also a second engine breather that runs through the centre of the crank drive shaft exiting at 6 'o' clock behind the engine sprocket end of the primary chaincase. Although little, if any, oil is blown out through the breather per se,there is nothing to stop oil from the mains making its way out along the shaft and out the breatherhole in the crankcase- this is why the primary chaincase often appears to leak yet never runs out of oil.
If there is a lot of oil coming out of the breather then, provided the rest of the motor is in good nick, it's worth checking the pump for wear on the scavenge side -after 65 years it's probablysucked the remains of at leasta couple of big ends through it by now!!!
Regards,
Ian.
Thanks for the great replies! I will check the crankcase breather and run it into a jar to see if that helps. That's what I do on my Commando. Is it possible to machine the gearbox for an oil seal behind the sleeve gear on the older gearboxes? I guess I need to try to figure out if the oil on the tire is engine or gear oil to determine how much if any of it is coming from the gearbox. Thanks again.
