New Featherbed and Commando frames
This may well be old news for many Noccers but I've only recently found out that Andover Norton are producing wideline featherbed frames in the manx stye, but all-welded, for a reasonable £825. (P/n 06-7201) Commando frames too - early type for £815. See here - http://www.andover-norton.co.uk/SI%20Frames.htm. Handy if you've had that little accident with a tree or a train! Or if you work on a construction site and a tracked 360 has run over it!
As I posted elsewhere, you thenjust need a set of 7mm number & letter punches to add the frame number. (Unless they come already numbered of course - I'll check)
Cheers,
Lionel
Hi Lionel,
are these frames good? Has anybody purchased one and had any problems with it? I need a 1971 frame. Part # 06.5404
Any advice appreciated.
New member.
Richard. ( Australia).
