Hello George. i haven't g…
Expensive seat! I've take…
its about the only thing t…
its about the only thing that will hold my weight now lol .don't let it put you off buying one i still use mine but i thought i would just point that out. Baz
yes i used small ratchet s…
yes i used small ratchet straps there arnt any strap loops on mine so just drilled some holes to suit i do prefer the other lift i showed you with my bike on it its more stable . baz
Thanks Baz. Fair point - b…
I've ordered the Timberte…
Well Baz, I got what I pai…
Hello George . yes i know…
Hello George . yes i know what you mean . personally i don't use the bolt on y shaped supports i just use the flat base with a piece of marine ply inbetween cut around the important bits to keep it level . also i support the wheels underneath just lower it down onto something so it just touches it help with stability especially when taking a wheel off and the weight distributions will alter sending the bike in the opposite direction. i would just practice with it. all lifts and jacks have there limitations i suppose, safety at all times. Baz
Previously Barry Carson wr…
Forgive my ignorancebutwhat do you usethisliftfor? And whatdoyou straptowhat??
Hi Jon - I got fed up craw…
Hello Jon. there are no st…
Hello Jon. there are no strap loops on mine i suppose some could be added if required. i suppose its really a secondary lift for a table type lift with the bike strapped to the main table. or it can be use on its own. Baz
That's right,`Baz. There…
Thanks Baz. They look as t…
The cleats finally arrived…
Hello George. i haven't got the model you are on about but i have the same type the only thing i had trouble with was the pin that held the threaded bar to the nut that raises or lowers it came out and the bike hit the deck. it happened just before i could insert the locking bar luckily the bike fell against the shed i now use it as an adjustable seat . Baz
