Layshaft bearing
Dear Members,
What would be the reason that I cannot remove the layshaft assembly from a dismantled gearbox? It's in situ, but all the removeable gears are out and I can't quite understand, as it's in a roller bearing why it is firmly stuck. It rotates freely.
Many thanks.
Al Bentley
It may have been Loctited in by a PO due to a wear if you haven`t been in there before yorself. You may need to heat up the case with a hot air gun (always recomwnded) and pull the bearings.
Good luck, Al.
Slacken gearbox top and bottom bolts, if not already loose.
As above, just hope it has not been secured using high temp bearing or shaft fit. Most break down at around 230C, but need 2 or 3 cycles to degrade it.
If the primary has been removed just take the box out and get some serious heat in the shell on a bench. Heat the shell with the primary facing end uppermost, heats the bearing recesses quicker and saves gas.
I can see the clutch push rod in the main shaft, I presume that you have removed the clutch first along with rear chain sprocket etc.
Dick
Should have gone to spec-savers, I've just reread the mail and it is the layshaft you are trying to get out.
Dick
Really useful information. Many thanks to you all. I'll have a go with some heat tomorrow.
Regards,
Al B.
Al, you have had some good advice above, but no one has said what might help you understand what could be going on.
The layshaft bearing is normally a ball race that does not come apart. The outer is a heat shrink fit in the alloy case that MUST be heated to 200 deg C or thereabouts to get it out or back in again. A powerful hot air gun is ideal if the gearbox is in the frame. It is much easier to have the gearbox out, on the bench, and give it a thump down onto wooden blocks when hot. But, a hot shell should release the bearing easily.
The layshaft is a light press fit into the bearing inner race. It might just come out in your hands, yours does not.
It will all be more difficult if the parts were worn and a previous owner has reassembled with loctite. As said above, you need more heat to break down that loctite. It will have to be on the bench. It is much better to use a gas torch to heat the aluminium shell on the outside. If there is loctite present it will give off white smoky fumes when it breaks down. An IR temperature gun is a big help to know how hot you are getting it.
In reply to by norman_lorton
Dear Norman,
Many thanks for taking the time to explain the situation so clearly. What I didn't realise was that the layshaft bearing is a BALL Bearing. I thought it would be a simple matter of pulling the shaft out complete, due to the end of it fitting into a roller bearing. So, that all makes perfect sense now. I thought that perhaps the end of the shaft had become grooved, or something.
I only wanted to inspect the shaft and bearing, but as it it feels fine and rotates smoothly, I think I leave well alone!
The reason for all this is that I had no neutral. I discovered that the clutch spacer had been fitted with a replacement, which was at least twice as thick as the standard part. This mistake meant that the top gear sleeve was hard up against the spacer, meaning that the rear wheel was turning the engine over in the neutral position. All sorted now, hopefully and will report back when it's all together.
Many thanks again
Al. Bentley
You need to replace the ball bearing on the end of the layshaft with the roller bearing or the ball with a resin cage, the brass/steel cage on the ball bearing fails, the balls all fall to one side and the rings then move enough so the balls drop out. A sudden lock up happens when one of the balls gets between a pair of gears.
The layshaft is normally a close fit in the bearing , I use a mole grip on the end of the shaft and give it a tap ,a primitive slide hammer!. If you get the bearing out its usually replaced with a roller bearing which then needs some shimming at the kickstart side to control the end float. Or you could use an uprated ball race as recommended by Mick Hemmings a box specialist. You are right in that the back of the clutch needs a clearance to the sleeve gear, not easy to check, I strip the spider out and torque it up to check with a feeler gauge on my 99 and Atlas. Different to commando but the end result is the same.
