Jubilee oil pump
Got a some wet sumping going on and want to replace or repair the pump any one have any photos as it's all new to me as the bike runs fine . This is my plan for later .Thanks Keith
Hello there,
The oil pump lives inside the timing cover so it is necessary to remove the points plate and advance/retard mechanism before removing the actual right hand side engine cover itself. The pump is then easy to remove - just remove two nuts if my memory is right and the pump will pull free . Make sure you replace the oil seal in the cover and the seal between the pump and case as well. It's not a major job but drain the oil first. The NOCshop keeps the seals you need but I don't know about getting replacement pumps. I think the pump is the same as the Dominator.
Are you sure the pump is at fault? Every Norton I have ever owned has wet sumped if left more than a week or so.
Patrick.
