I would imagine that it wo…
George if its like the sin…
George if its like the singles I work on you got to have some oil to scavenge before it sends back up the return, where your rocker feed is connected. Now if you have been considerate when rebuilding and oiled mating surfaces as you go then starting and running with the return to tankblocked off to induce a higher flow to the valve gear will not harm anything. As the name implies, the rockers "rock" so a film of oil will last a fair while. Remember the king of Norton's has no oil to the ends of the rockers that touch the valve.
The oil feed is a hap-hazard affair as the demand on wear surfaces is low. as long as you have oiledthe relevant surfaces, start it and monitor the flow to tank.
It is not unknown to distort the entry into the tank to increase back pressure to induce more oil to therockers. Blip the throttle and you will get a spurt of oil amongst the mist andvaporthat returns. If nothing is arriving the problem is bigger than a dry rocker box.
No "expert" George, just trying to help....
You're all correct! I wen…
Bloody hell.... I hope the…
Bloody hell.... I hope they are not out of the Mag!!!!!
Thought you might be tinkering out there this beautiful afternoon.
Applying the "line of leas…
Applying the "line of least resistance principle" it never fails to amaze me that oil gets to the rocker box at all! But it does.
Ian McD
Reminds me of when I start…
Reminds me of when I started my 99 up for the first time, almost 18 months ago. It sounded wonderful (Still does) but after about a minute or so there was this awful chattering coming from the rockers. Off with the oil tank cap and finger over the return hole and a few seconds later normal noises resumed. Pure music.
That's just what I was tr…
What diameter and length b…
What diameter and length bolts?
You also had the rocker cover off recently as well?
Colin
Panic over. I removed the…
Ignore earlier rant. Panic…
Going back to my original…
i suppose you wouldn't ex…
i suppose you wouldn't expect a lot of oil in there until it had run a while. unless you have put some oil down the push rod tubes through the inspection plate hole on the rocker box .
Barry
10 out of 10, Barry. With…
If you had them you prob f…
If you had them you prob forget where you'd put them! I'm glad I'm not the only one who has a few bits left over from time to time!
I would imagine that it would need a bit more than just kicking over to provide enough oil return to feed the over head gear. Start it up and put your finger over the out let spout to stop the returnin theoil tank, this will see plenty of oil running up to the rockers.
