Hello I just fitted a new centre stand and had to remove the alternator (marking the connections) and battery, I have magneto ignition. Put it all back together and no lights! Was surprised when I found the battery was 12v as are all the bulbs, the alternator is a two wire job. I kick myself for not recording the battery connections but pretty sure it was negative earth, the leads are not long enough to connect the other way around and the battery can only be fitted one way round otherwise terminal screws would be inaccessible.The negative ( I believe) battery lead is red (but does go to earth) which may be a legacy of when it was positive earth maybe and there is also a white lead connected to it. The other single battery lead to the positive is coloured black/white and disappears into the loom. It has one of those little square solid state rectifiers with 4 terminals, when I checked the connection the terminal marked + goes to earth but remember this is now negative confusing or what!!! Not sure if I could have damaged it by possibly connecting battery wrong way around when I used some temporary leads. There is a zener diode that passes current one way only but I am not sure of its polarity. Lights were fine before and ammeter was indicating charging. You may have guessed I am not good with electrics and I don't know what to try next,concerned I may damage alternator if I start it up. Any help and suggestions most welcome thanks. Eventually I imagine I will replace all the wiring but for now just want to get some use out of the bike. Cheers Pete
What year is it?
It’s a 62, think i will go…
It’s a 62, think i will go with positive earth think the big clue is the + terminal on the rectifier being connected to earth good tip on the fuse currently not one present thanks
Dommy polarity
If you connect the battery the wrong way round the ammeter will move the wrong way when you turn the lights on. If you have a modern rectifier/ regulator you should diconnect that beforehand.
MODEL99
HELLO now the model 99 from september 1957 on electrics were on 6 volt and alternator was a RM15 3 wire and a ignition and lighting switch was the PRS8 so the wiring will be from this and had distributor ignition the D2 So the magneto as been fitted by a previous owners and all Nortons from bracebridge street are positive earth And the white with black tracer is for coil ignition wire yours anna j
Not true I'm afraid Anna....
.. my 1952 ES2 which is definitely from Bracebridge Street is negative earth and left the factory in that state (at least according to Edgar Franks).
Thanks for all answers i…
Thanks for all answers i strongly suspect that the fuse has blown just need to find it. Both battery cables disappear into the loom, going to see if it is hidden inside the headlamp. This bike has no ignition switch. Was wondering if wrongly connecting the battery could damage the ammeter causing a break in continuity? Years ago my dad had an old car with a dodgy ammeter and having to hold a penny across its terminals to get us home!
irrespective of what it was…
irrespective of what it was when it came out of the factory, It has now changed so start from scratch.
If you have a small 4 terminal rectifier and the positive goes to the chassis of the bike, you have positive earth.
You can yet -ve or +ve Zeners but is most likely a positive earth zener.
If you have connected the battery up the wrong way round, you have possibly blown the rectifier, zener or maybe just (if you are lucky) a fuse.
You will not have damaged the alternator or ammeter.
So, start out with the zener and rectifier removed from the circuit and find out why volts from the battery are not getting to the lights. Switch / fuse / burnt wiring / incorrect wiring. Once you have done that, you should be clear which is positive and which is negative.
Connect the zener back into circuit, lights etc. should still work.
Connect the rectifier back in circuit, lights should still work.
Start the bike and see if it charges. If not you have probably blown rectifier up. If it charges but the volts go above say 14V then the zener is toast.
norton twins
hello Ian try follow the thread witch is about Norton twins nothing mentioned about Norton singles and I had a 1951 model ES2 and it had positive earth So how do you know this ES2 left bracebidge street with a negative earth As to me I find this odd, Has even my 1971 morris minor has positive earth yours anna j
All sorted one of the leads…
All sorted one of the leads that I assumed was for the negative battery connection was a dead lead just capped off inside headlamp, used twp remaining leads positive earth, thanks for help though
Workshop manual for 1954 16H…
Workshop manual for 1954 16H, Big 4 18 and ES2 shows positive earth.
Workshop manual for exactly the same list of bikes but without a date shows negative earth.
Does this help or add to the confusion?
Can provide pages from the manuals if you want them.
Polarity?
We could argues this subject for years-some facts, as far as I can ascertain Nortons were Negative earth up to 1952. 1953 all Nortons from the factory Positive earth. IF you know otherwise prove it, i.e. show me the document?
Mikael R- Nortons never fitted a fuse in the Earth line either. (Triumphs did). It would also appear that Fuses only came in from the factory with the Commando (and perhaps the last of the Atlas, Mercury). But of course fitting a fuse to any 12V bike is almost obligatory, 12V has a nasty habit of getting out of the battery into the wiring and causing smoke and grief.
Zener diodes-80% of these were positive earth. The modern square 4 terminal rectifier, if bought from a reputable supplier should be virtually bomb proof, the alternator in this discussion is bomb proof and the connections to it are reversible. In this saga there are battery wires of the wrong colour-why do you do it? It adds to every ones confusion, non working, smoke, expense. Your choice.
Peter Brown-if you need any more advice, wiring, please get in touch aoservices.co.uk
Erath fuses..
.. I always fit one in the battery earth cable as it's so easy to short out the live terminal with an errant screwdriver etc. Yes I have done this......
Of course this works for both negative and positive earth.
The Edgar Franks book I referred to was first published in 1948: my edition is 1949.
Further
Shorting the battery-easy done. There is a rule in the car world which remains true for bikes as well. You have to think about this-Disconnecting the battery-Earth first. Reconnecting-Earth last.
Saves having a 'welding hole' in your screw driver. But the story above by Mikael R inferred that Norton fitted a fuse in the Earth line-they did not.
Very foolish
Very foolish to use Haynes-known for upside down pictures of the wrong part. But if all else fails they can be a starting point. OK Mikael
Dommies had a number of different wirings. So year of make could give a clue. But many of them have had changes done. All of them left factory with positive earth. Not all today. Lot of them have no fuse connected to the battery. Fitting a fuse between battery and earth, as Norton did on some late machines is a good way to prevent a reversed battery to cause the famous Lucas smoke or killing rectifier and Zener.
I'm not certain if there ever was any negative earth zener diodes, all I've seen has been for positive earth systems. Anyhow you have to test both zener and rectifier. It would not surprise me if battery terminals isn't accessible when fitted. Have a couple of vehicles like that.
