Crankcase identification marks
Do Norton twin crankcases have identification marks to indicate a 'pair'. If so, where should they be found?
Yes, both crankcase halves are hand stamped. The numbers should be the same. The drive side half is normally stamped just above the bearing housing and the timing side half near where the idler support for the timing gear is fitted
