is this the correct air slide[choke]
seems to be smaller than I remember....it's brass
Attachments p1010008-9-jpgLooks OK to me. As long as…
Many thanks! I just though…
Many thanks! I just thought it didn't restrict air flow much
I don't know what the oth…
I think you're right - I…
I think you're right - I hadn't realised the magnification was so much! Of course the slide should fit quite nicely into the hole in the throttle slide that we can see.
Well spotted Rod.
a better photo, there is a…
a better photo, there is a guide and the brass slide is shown in the down position, but if memory serves me right, it is smaller than on previous bikes[mind you are going back 50 years!]
the slide goes down and does restrict the air a bit, but there is nothing to support it......it just hangs loose
Attachments p1010017-3-jpg- Log in to post comments
The slide usually locates…
The slide usually locates in that cutout in the throttle slide and is a sort of top hat section so I think what you're showing is incorrect.
You can see it on the link Rod posted.
What you have does look similar to the one I had on the 1931 Sunbeam I restored recently but TBH I can't remember exactly what that was like (Amal Type 74 carb).
Oops! My apols, John. Rod…
Oops! My apols, John. Rod is quite right. I've just been down and shone a torch up the carb orifice and the air slide completely covers the width of the opening, stopping short at the bottom to allow some air through. Like Ian, I was misled by the scale. George
Many thanks again, I wonde…
Many thanks again, I wonder how many other 'problems' I'll find before I get it on the road........ I bought it in good faith from a chap who said he had it running beautifully but because of ill health couldn't ride anymore!
still it will keep me out of mischief this winter.
And a very strange tank fitting!
Attachments p1010011-5-jpg- Log in to post comments
Funny, that's what the ve…
Funny, that's what the vendor of my ES2 said....... I have yet to seriously delve inside but am not encouraged by what seem to be metric Allen screws holding the rocker cover on.....
The tank fitting will provide a source for making new nuts.
It should run ok without t…
It should run ok without the choke slide but you should remove the brass guide and cable and seal the carb top with a small nut and bolt.
i removed my choke slide a…
i removed my choke slide and associated parts and just siliconed the hole that was left it worked ok .
Looks OK to me. As long as it retracts fully so it doesn't protrude on WOT and is able to go down fully it should be OK.
