Hello,
Following on from my last post and query in September, my 1963 Atlas is now running (kind of) and back on the road (well,…). Following great advice the last time, I reverted from 376s to the original 389/88 and /87 Amals which I found on Ebay in excellent condition and replaced a lot of parts, bringing it back nearer original condition (incl. Chronometrics, respray, MCH61 headlamp shell and John Tickle tls break, obviously not original…) . A magneto rebuild, fitting Easycap condensers and switching to 28 degree advanced has sorted the ignition issues.
However, a few minutes after starting, I get white smoke from the exhausts and wet plugs and I strongly suspect it is from over-oiling the head and possibly worn guides. New 8.9:1 pistons and rings were fitted (with 120 degree gaps) in recently sleeved cylinders. The set-up is low pressure head feed, 6-start ‘S’ oil pump, scrolled spindles, cartridge-type oil filter, using 20W50 classic oil. Oilways in the head and block are clear, an anti-drain valve rules out wet-sumping.
I plan to fit a new valve and guides kit soon (RGM colsibro but without seals as my Atlas is 1963 and has short valves) - this hasn’t been done for at least 20k miles, so it is probably time. However, I am also considering the following options as I am at it and would appreciate some advice which route to take:
1. Change the 6-start pump gear back to the original 3-start cogs, but the bike has the later conrods with the oil hole in the shoulder, but I am not sure if matching b/e shells are fitted. If they are, can this set-up be run with the lower pressure of the older 3-start pump or do I risk a cataclysmic big end failure?
2. Somewhere it was suggested to restrict the low-pressure feed slightly by either crimping or soldering up and re-drilling a smaller hole in the pipe of the banjo feed to the head. Sounds logical, but somewhat crude…
3. Leave the 6-start pump in place but change the the inlet spindles to flat-type ones and retain the current original scrolled ones for the exhaust.
4. Leave as is, run in the pistons for a while and hope the smoke will disappear by itself… But I risk that the plugs will foul and I will have to de-coke the head every season.
Any advice, suggestions and warnings are much appreciated!
Holger
Restrict the flow to the…
What type of piston rings…
What type of piston oil rings are fitted.? the earlier one piece were not up to coping with the drilled rods.
Looks like our Atlas ! You…
Looks like our Atlas ! You need to find out if the extra oil holes in the rods are in use or blocked. You could pressurise the end of the crank from the timing side and look through the sump plug ( hire an inspection camera?.) . you can then decide your direction. I would return to the 3 start pump set up . If however the rod bleeds are in use you should use the 6 start with all that entails, solid spindles, bigger oilways , multi piece oil rings and I would convert to inlet valve oil seals with later guides. Done this on our late Atlas , they may not last as long as the orriginal guides but the limited milage makes it practical. OR. take down the motor and change the shells round and fit 3 start .
Options
Thanks for the advice! I think I will give the restricted rocker feed option a try to get me going for a while (I couldn’t find a suitable jet but a small TIG torch collet fits the oil hose perfectly). However, I am tempted to revert back to the 3-start set-up eventually to avoid all the other changes (the rings are Hepolite R26260 btw). The idea to pressurise the crank is a great idea - I will do that when the head is off for the valve change anyway, removing the barrel should make it easy enough to observe the oil holes and also to check the piston rings. If the oil holes are in use, I have to bite the bullet, taking out the engine and to split the cases…
Well the oil is either…
Well the oil is either coming up via the rings or down via the inlet valves. A quick way to determine which is to block the rocker feed and go for a short ride, the rockers will cope with a few mins with the oil already there, if the smoking reduces then its likely its the inlet guides, if it stays the same then its likely to be the rings. If you are reluctant to do that then take the carb and manifold off and look at the inlet valves, there should be evidence of oil on the inlet valves if its the guides.
oil problem
I think that 6 start pump is good for every engine than 3 start(Bearing shells must be oiled well) I have 6 start on my 650 ss and it works with no problem
i dont know if somebody make some changes with other parts but it works well and i dont see why it will not work on your bike.
I dont know how skilfull you are, ? take head down check if are rocker arms free for oil, check valve guides if they are not oval and for me is big problem when is valve guide little free in head and oil goes to head between the valve and head. if you want to check this you must head warm up and valves must still hold in head if they go out or have some clearence problem will be here. ia have same problem on my commnado.
good luck and sory for my english
you have very nice bike.
https://freebiker.rajce.idnes.cz/dominator_oprava_motoru_2019/
I think that an engine with…
I think that an engine with perfect valve guides and piston rings may tollerate the fitting of a six start gear set , but thats not allways the case. It often ends up with oil pooling in the inlet guide area and the distributor/mag getting too much oil passing through.
Valves
Hi Tomas and Robert, the valves and guides are definitely on the cards sooner rather than later, as they havent been done in the time I had the bike, nearly 30 years (even if 15 years off the road)… It being a ‘63 model, I will probably stick with the shorter valves, rather than changing the pushrods as well. I read various opinions on wether to go with the silicon bronze guides or the standard cast iron type. Tending towards the bronze - which ones did you go for?
John - I will try blocking the feeder for a short time to get a better idea where the oil comes from…
valve guides
Hello on my 650 ss my friend makes valve guides bronze from same material which is used on modern BMW motors.
I have guferos on inlet and exhaust valves and it works perfect i was afraid first that can make some problems with guferos on all valves but it works. bike has minimal consumption of oil.and now i about 2000 miles from this repair
on my commando i make head too but 5ears ago i use cast iron valve guides and guferos on inlet
becasause in that time i havent money for bronse and dont know good people. :-)
but commando runs very well and oil consumption is ok about 1/2l for 1000km
it is better than new bike :-)
foto of old valve guide in my commando
Hi, just ran her without the…
Hi, just ran her without the rocker feed as suggested by John and there is still a lot of smoke and wet plugs, so it appears to be the new rings! That makes sense as I don't remember to have the white smoke problem in the past and only changed the pistons and rings recently. The Hepolite oil rings are single piece items (with a spring), while the previous ones were triflex rings. I might try to fit the old rings as they have done less than a thousand miles and the ring gap in the pistons is the same. There still appears to be a lot of oil in the rocker area after re-connecting, so I might try restricting the flow a bit too as suggested.
Thanks for the info on the valves, Tomas. I will see what is available - I know that RGM does valve overhaul kits, so will check with them.
Ring Ring
Some piston rings have to be fitted a certain way up . If you get them upside down then you will get over-oiling problem. Usually they are marked with 'top' on one face but not always. See the attachment for my replacement pistons.
I recently fitted an RGM cylinder head overhaul kit to my 650 Norton. This had Colisbro guides. The kit also contained rubber boots for the inlet guides. This set-up worked really well to begin with and completely cut the smoking problem that I previously had; especially on a cold start.
However, the smoking returned very quickly and the engine lost compression on both cylinders. I pulled off the head to discover that the exhaust guides and valves were seizing and also both of the rubber boots had jumped off the inlet guide ends. The seizing valves had tapped the piston tops and consequently bent themselves and their respective guides. I returned to using Iron guides and these have been fine. I was wondering if Ethanol in the petrol was the reason for the valve problems?
Hi Phil, When I did the…
Hi Phil, When I did the Atlas I was faced with the same issue and decided to fit Commando guides although in theory being shorter they may not last so long, the seals lock onto the guides.I have also read that valve and guide material need to be compatible ,( not that i know much on the subject !) . I have fitted 5 piece (similar to Cords) rings to the old well worn pistons and the smoking has gone ,at least for now.
That’s a revealing…
That’s a revealing experience, Philip - in theory both cast iron and silicone bronze should be self-lubricating. I wonder if the seizing had to do with wrong tolerances and different expansion rates of the various metals in the head. Maybe sticking with the iron ones is the way to go, so - RGM are offering both iron and bronze with inlet seals for early Atlas heads. Were the guides standard size or did you have to lathe them down to fit?
I took the head off yesterday to check valve and pushrod lengths and there was a lot of oil… The barrel will come off today to swap the oil ring for the previous triple scraping ring. I am a bit unsure about what head gasket to use - it is an early head with 5/16” bolts but the spigot has been machined off, assume when the cylinder liners were fitted. No rings were fitted to he head, but I will get two from RGM. I dont really want to go down the route of changing bolts to 3/8”, if I can avoid it. Not sure to use copper or the copper composite? With a smear of Wellseal or not?
Robert - yes, you are right …
Robert - yes, you are right - about twenty years ago, Norvil did a major job on the cases and barrel. Pistons were then so oversize that they recommended to fit liners and bring it back to standard. The crankshaft was balanced and the journals submersion welded back to standard, as the they were too worn and later conrods with oil holes were fitted. I think then, using a 6-start pump and cartridge oil filter was then recommended, which started my current over-oiling troubles. Strangely, I laid up the bike shortly after that major work was done and I only pulled her back out of the dusty corner last year…
Update…
No worries, Robert - you left the important ones!
Ok, just took the barrel and pistons off… Turns out rhs had triplex oil ring, lhs a single one fitted - that’s the side that was smoking! I also discovered pressure marks on the skirt of the lhs piston, so I will get the piston clearance of the Norvil-fitted cylinder liner checked and honed to 4-5 thou in an engine shop.
I also pressurised the crank to see if the conrod oil holes are working as suggested by Robert. They indeed open when the piston is down and squirt out oil, as I learnt the hard way (I was covered in it…).
I am considering to stick with the 6-start pump for now, fit back triplex oil rings on both pistons and upgrade the a valve gear to iron guides and seals from RGM. As the barrel is in the machine shop anyway I will get the oil return bore widened from 3/8” (4.5mm) to 7/16” (5.5mm) and do the same to the head and crankcase, as everything is off. Leave low pressure return feed and scrolled rocker spindles as is.
Btw, does anyone know if the RGM valve guides need to be reemed and are they standard or over-size, i.e. need to be turned down to the head?
I think you will have to…
I think you will have to determine what size guides are already in there and if they are tight or loose ,before you can buy new. Will be worth putting some sealant round the guide flange in case there are any paths for the oil .
In the past I had guides …
In the past I had guides (not on a Norton) that had to be reamed to fit the valves. RGM does not specify any oversize dimensions, so I suspect they may come oversize to be turned down to size. Waiting for their response at the moment… a bit of Wellseal is a good idea.
Colsibro valve guides and seals
Unlike cast iron, Colsibro guides are not self lubricating. In the absence of a decent oil supply, they will pick up. So should you omit guide oil seals if you fit Colsibro guides? I would.
Meanwhile, just fitting a 6 start oil pump shouldn't cause major problems, something I did on my 99 years ago. However, the 99 rocker oil feed was just the low pressure take-off from the oil return line. I suspect that with the Atlas pressurised oil feed you really should have plain rocker spindles or over-oiling of the top end is a distinct possibility.
When I did Dommie valve…
When I did Dommie valve guides, they were available in several oversizes but none large enough. I bought 850 Commando guides (which are larger diameter znd diffraction outside shape) and turned them down to fit the Dommie. Can't remember clearance..about 2 thou I think.
Valves and guides
http://www.gsvalves.co.uk/phone/index.html
This website has information about valve and guide compatibility. Problem is..I'm not convinced our suppliers know the valve stem material or surface finish. And they don't seem to list suitable guide material alongside each of their products although I expect they will help.
And I suspect from reading elsewhere that the best material for low mileage high reving racing might not give the long life needed by a road bike. They do seem to say that "bronze" (which is copper plus tin) is not advisable, but Colsibro is copper plus silicon...etc..so not bronze in the traditional sense.
Normal tin bronze is…
Normal tin bronze is somewhat porous and the silicone has the ability to fill pores during the casting process, making it denser and harder. As an added benefit silicon adds a limited self lubrication quality to the metal, making it ideal for valve guides. Many bronze bearings are essentially compressed bronze powder with lubricant inclusions, as such self lubricating, but I dont think this applies to the Colsibro guides. Very interesting website, btw!
Maybe worth sticking to the old rule iron for roadwork and bronze for racing? In the end the advantage of bronze guides is improved heat transfer (but only 25% through the guide according to that website, 75% through the valve seat) but cast iron guides offer a reliable compromise between durability, lasting tolerances and cost.
Happy days…
Just a quick update on the above query and discussion. The Atlas runs fine now after more work over the last weekends. Happy days!
- I changed the rings back to the Twiflex (spring and two rails) oil scraper rings. I had to use the old pistons as the grove was not deep enough in the new ones which meant having to polish out a few marks and light scratches. Got the clearance checked and the cylinder liners honed to 4-5thou. The rings cured the smoking, so I did not have to change the pump or BE shells in the end.
- I ordered iron guides and valve kit from RGM, but left the old guides in for the moment as the play is still acceptable (healthy plop when valves are pulled). Turns out inlet guides are bronze already with seals but the exhaust are iron.
- Despite reconditioned carbs, complete magneto overhaul with EasyCap condenser, new plugs, checking ignition and valve timing several times, new leads and caps she still ran on one pot. The magneto cam is 3 degrees different for the two cylinders, but acceptable when difference is divided. This nearly drove me demented… In the end it turned out that one of the brand new Champion plugs was faulty! It produced a healthy spark when out but was dead under compression! First time I experienced this…
Thanks everyone for the help, advice and suggestions!
Holger
Restrict the flow to the head by adding a restriction to the rocker feed oil line. Needs to be about 1mm/40 thou so an Amal jet of suitable size will do.
