1928 Enfield hub sprocket
Does anyone know where I might get a rear wheel sprocket for my 1928 CS1 with the enfield rear hub?
If your hub is the same as my 31 model 20  you can have a sprocket fitted to the old one.
My machine shop removed the old sprocket at the Fingers then welded the new one on .Perfect
The Scott sprocket is close to mine but the offset  is off a bit.At worst I'm not sure if heat and a press might  put it right.
I did think about that, but the sprocket that I have is not norton. It seems to have the wrong dish and is for 3/8th chain.
