I've just picked up a 67 Cafe Racer. It has been sitting for 5 years, and I'm looking for someone in the Northants/MK area who could take on the project of getting it serviced, cleaned up, and running well. It was reportedly running very well when it was put to bed.
Is anyone aware of a relatively local facility/specialist who could do this for me?
ArJay
Lovely look?
Hi Alan, I appreciate your…
Hi Alan,
I appreciate your thoughts. All valid, I'm sure. But here's the thing - I'm an old Harley guy (moved here 2 years ago). I have some medical challenges related to my muscles, so I gave up riding bikes 15 years ago. But I love the art that bikes can present. And I recall my early days when cafe racers would scare cars and pedestrians along Pacific Coast Highway in Southern California where I lived, and watching them blast along Mulholland drive.
When I saw this bike, and just loved the look. I am admitting right up front that I'm not bothered about the originality, or even the performance. I just love the look. So that's why I bought this bike. Not to do long fast rides - I'm not physically capable.
It's a numbers matching bike, but its had a number of things done to it. For example, a brand new hand made tank. If you're curious about what else has been changed:
New aluminium mudguards front and rear
Hand-made stainless steel clip-on handlebars
New wheels built by a trained wheelwright, with stainless spokes
and aluminium rims
Aluminium café racer oil tank
Hand-made stainless steel chain guard
New stainless steel tank straps
New aluminium top yoke
New clock mounts
New headlight with ammeter
New rear shock absorbers
Twin carburettor upgrade with two new Amal concentric carburettors
(ignore the non-Amal trumpets - its the look :-))
New brass fuel taps
New chain
New clutch
New clutch and brake controls
New throttle
Vented twin leading-shoe front brake
Electronic ignition
New exhaust system including downpipes and silencers
Definitely NOT as delivered in 1967.
I love the look. But I want to make sure that if I ever manage to sneak away from my wife, and drive around the block, it is in perfect working order and as safe as possible mechanically.
So you are absolutely right about the bike not being a legit 1967 as it was Atlas. I apologise if that causes you to rant, and I respect your experience and views. But on my side, it was all about the looks.
Thanks!
ArJay
I initially went to the…
I initially went to the branch website and signed up/in. Surprisingly, the site is basically empty. An initial welcome from 2022, and offers of WordPress training. Nothing since that initial creation entry. That's when I came here.
Help available
Hi ArJay,
Is the assistance needed of a professional (ie a shop) or an enthusiast nature?
I live in Northampton and would be happy to meet you and discuss what needs doing.
I would describe myself as a competent enthusiast/mechanic and very little fazes me with bikes so I'm not really up to date on where to best go for professional help.
If this would be a help, contact me by private message with your contact details.
I will also add that next Wednesday (14th) the Northants and Leics NOC will be meeting at The Wharf Inn at Welford (on the Northants/Leics border) from around 6pm. By all means pop along and say hello and you will get other members advice on where help can be sought.
Regards, George
Thanks, George, on both…
Thanks, George, on both accounts. I'll hold off on coming to bother you - if I don't end up finding a professional resource I will definitely come and ask you :-)
As far as the tri-monthly meetings, in my search I came across the notes about the three meetings a month for the branch. Sadly I am away next week, but I will definitely come to the next meeting. If you go, I'll see you there and thank you in person.
It looks like someone fitted…
It looks like someone fitted a Commando carb manifold. They turn down to compensate for the engine being tilted forwards. Twin carbs on the Atlas etc should have straight spacers so the inlet passage is dead straight before it reaches the inlet valve.
Carb manifold - check!
Thanks David, noted, and I'll pass it on when I eventually find someone mechanically minded who takes on the job. I forgot to mention - I am absolutely clueless mechanically. :-)
Originality?
I never said I was/am an originality freak. I like the look of it but I still dislike swept back pipes as they get in the way as soon as you want to do any work! The front brake appears to be early Commando TLS fine a good mod, but it still appears over centre and needs resetting.
Glad somebody else sees the carb manifolds being wrong, The carbs should be down draught not horizontal which the appear to be.
faults
those inlet manifolds are very odd. can you post a close up of a carb. and manifold?
The front brake levers on the hub are at a very odd angle: never seen them at such an angle, which is potentially very worrying as to how the brake shoes /linings have been set up, or more likely, that the levers have been fitted to the pivots the wrong way round: the fitting slots in the arms are at a slight angle to the length of the arm.
OH DEAR!
Front brake is over 'centre' makes it extremely inefficient-unsafe even. The araldite oil tank pipe is also a disaster waiting to happen.
The carb manifolds are Commando, wrong for the Atlas. This should have Atlass/SS ones (think they are the same) but do check the bore of head, manifold and carbs are compatible. Remove the carb trumpet and run without before putting it back (if you must) Observe the drop in bottom end performance first.
Have fun.
Yes, front brake needs…
Yes, front brake needs dismantling and correcting. Inlet manifolds look ugly , I would consider swapping for a single carb and manifold which will look better and be a heck of a lot easier for a newby to classic bikes.The carb trumpet is too close to the battery and will block airflow. These are pretty basic errors and makes me wonder how safe the rest is.
arjay_joffe apologies for…
arjay_joffe apologies for the rude, stuffy and narrow-minded comments you have received.
Your bike looks great and welcome to the world of Norton ownership!
Lovely looking bike BUT (going to have a rant now) How I hate swept back exhaust pipes, as soon as you go to do anything-pickup a spanner etc the pipe is in the way, and they don't help cornering that I have ever been able to do....even though they look great!
Another look great but actually slows up performance is those cheap carb. trumpets. The Amal ones work-those don't. Just take em off and see what the difference is with bottom end punch? But shouldn't they be down draught?
Another point, the front brake looks over centre so needs looking at.
