Here are some really useful modifications I did on my Atlas which have improved it quite a bit:
Thorspark Electronic coil ignition - easy to install into a KF2 magneto without having to remove it first, not overly expensive, very simple, fit and forget. Engine fires first kick.
RGM anti-wet sump valve - really useful piece of kit that automatically prevents wet sumping, Fit and forget, and it works too!
Lucas Ignition switch - positioned on the instrument bracket for easy access
Positive Earth NCLD (‘Not Charging’ Lamp Driver) - a small diode that fits inside the headlamp shell and allows you to see if there’s a problem with the charging system
Twin air filters - Makes adjusting and balancing the carbs much easier and quicker
USB jack - positioned on the instrument bracket allowing easy connection to a phone or sat/nav. Works fine with positive earth but you have to be careful not to short out the lightning connector on the frame. It did that once and blew the main fuse!
Adjustable alloy dog-leg levers - much easier to use, they look the part and have additional cable adjustment
Roadrider tyres - awesome roadholding quality
Hagon rear shocks - big improvement on the originals
Indicators - these days they’re needed
Modern L/H Indicator/horn, lights switch - easy to use and doesn’t look out of place on a classic bike
Softie grips, neoprene pads under the seat & gel pad above seat - very good for reducing vibration to the rider
Bar end mirrors - natty little adjustable mirrors that give excellent rear vision and don’t blur much
Instrument bracket - made from alloy sheet & polycarbonate. Enables placement of the USB jack, on off lights switch and ignition switch as well as facing the tacho and speedo more towards the rider so they’re easier to see.
Fuel Diamond - simply drops into the tank and purportedly prevents ethanol problems by preventing the bacteria that produces the acid that attacks parts. Stops octane dropping. Guaranteed for 5 years. Whether it actually works or not is anyone’s guess.
Reverse cone Mega - Not to everyone's taste but the original cigar exhaust was FUBAR and I simply love the sound this makes. It also only cost me £26 and because it has siamese pipes I only needed one!
Few more pics
I finally removed my…
I finally removed my siamesed pipes earlier this year after foolishly putting up with them for far too long. Only now is the bike running properly at high cruising speeds. They were (unknown to me) causing imbalance at speeds over 60mph and probably caused a piston crack incident at 70mph a few years ago.
It might simply have been poor fabrication and yours might be better. But the internal join from the side pipe was not clear enough because the pipe internal hole size wasn't a close enough match to the oval hole in the direct pipe.
I thought the siamesed felt as if they gave a small amount of increase torque during acceleration, but realise now they reduced top speed and caused more vibration and, I believe, piston damage. The "improvement" was probably wishful thinking after spending unnecessary money on them.
Have you inspected the inside join carefully? Have you done any motorway speed running alongside modern traffic yet? If it doesn't whiz up to well over the legal limit, take care.
Interesting. This bike has…
Interesting.
This bike has a smaller engine sprocket so it revs higher than normal, though I've never ridden an Atlas before so I don't know how it would feel otherwise. The fastest I've taken it up to is 80mph which, to be honest, is as fast as I want to go on an upright, unfaired old boneshaker anyway. Because the gearing is quite high it can be left in fourth a lot of the time and it pulls like a train from fairly low revs, which is surprising considering it has high comp pistons.
Since I sorted the carbs the lumpiness at lower revs has disappeared, it cruises smoothly at between 60 & 70 and the acceleration and torque is awesome. Very pleased with the way it sounds too with the reverse cone mega.
I've never had the pipes off so I can't comment on how smooth the internals are.
This ol' bike reminds me a bit of a 600 Ducati I once had. It just wants to go, go, go!
I'm never going to do long distance touring or much motorway riding on it. I have a TDM 900 I use for that kinda thing.
Good point I don't quite…
Good point
I don't quite understand your second sentence. i.e. "Covid cops"?
Covid cops.
Those who have been enforcing tyranny.Our freedom for money.
I guess you are compliant with tyranny, Stan?
Anyway, any issues with the anti sumping device, Graham? I cured most of mine by engineering out the pump wear to the engine. All new parts available from RGM.
Enjoy it while you can and good luck to all.
Oh, those guys! I wouldn't…
Oh, those guys! I wouldn't worry about them, they'll be broke soon.
No probs with the anti wet sump valve (yet)
Brake and clutch levers look…
Brake and clutch levers look to have distance wider than 7/8” between pivot and nipple centers?. If so will work but with reduced efficiency. Hard clutch , iffy brake. Also very wide reach makes for slow response in an emergency.
Good point, but these are…
Good point, but these are dog leg levers so the lever action is less
20M Improvements
Zim, hi .Great photo essay, l hope more people are "allowed" to do this. Maybe l should- . You didn't mention th very useful 2LS, is apparent in th pics. Also, l like th touch of p0l*t*cs, can be entertaining. Until someone looses an eye. (One-eyed?) . l agree with your comments on MPH, th atmosphere seems insistent after 80.
l may presume that as you enjoy the middle gears, you note th tachometer? Those short con-rods that deliver joyful midrange torque, may make a break for freedom if their joyousness becomes unbound. Atlas shruged. Continue to be happy with it. .
Hi Graham, I would re…
Hi Graham, I would re-consider those levers as they are giving the cables a hard time with sharp angles that will make for heavy action and fast wear. Perhaps a slightly different handlebar will allow them to work at a better angle ?.
“Submitted by Robert Tuck on…
“Submitted by Robert Tuck on Fri, 20/10/2023
Hi Graham, I would re-consider those levers as they are giving the cables a hard time with sharp angles that will make for heavy action and fast wear. Perhaps a slightly different handlebar will allow them to work at a better angle”
Yep- that front cable is going to fray, then break or jam. Get the basics of maintenance and safety right, before embarking on clever modifications.
“Fuel Diamond” sounds like total garbage to me.
Great Looking Atlas
A very tasty restoration.....looks good.
I like the handle bar end mirrors......I must get some for my cafe racer.
If I have read your engine number correctly this was from a large batch of Atlas models that got shipped off to Berliners in Spring 1966. The frame looks to be from a slightly earlier model.
Only suggestion to improve your bike would be to check the tension of the rear chain which looks a little tight to me. On the mainstand you need at least 3/4 to 1" of slack, otherwise the teeth on the gearbox and brake sprockets will start to get damaged.
Most useful mod
For me it was transforming the bottom bolt holes in the rear engine plates into slots, making it possible to remove the engine without disturbing the gearbox.
Otherwise it was 12v electrics and heated handlebar grips.
Usefull mods
Hi Graham, Sorry if we are raining on your parade !, it’s normal , there are lots of old salts here who have seen it all , but will happily give their time and experience if and when you really need it . I too have one of those mirrors with the extra elbow joint and it’s perfect in a narrow corridor folded away , Phil’s spotted the tight ? chain as I did , the last 4 bikes I worked on all had tight chains which destroy bearings and cause horrid vibrations , Norton boxes are prone to movement , well worth a regular check till it settles down , I like the tank cover and Siamese pipes , very practical, See you out there!
Bar end mirrors are the only…
Bar end mirrors are the only ones that don’t fall to bits on my vibey old twin.
Electronic ignition isn’t a bad idea, but I prefer to be rid of the magneto’s bearings and paper daisies.
Not forgetting the footrest
The RH footrest seems low to me. Perhaps one serration up? And the other mod on my one - a single carb. Suits the lazy mechanic down to the ground. Only one choke and throttle cable, no carb balancing. Ideal.
I found setting the…
I found setting the footrests low made gearchanging difficult with proper riding boots , it did not do rear wheel braking any favours either ,. and made setting the std brake light switch unreliable . Better to put up with knees too high .An extra long (welded) gearchange lever and some raised handlebars with a sensible riding position makes it all work. .
Few more pics
