Jubilee brakes
Are the front and rear Jubilee brake shoes the same.
John.
Yes John they are the same and are interchangable, Don't forget the loose steel slipers that fit over the ends where the cam bares, the original shoes had no cast in steel inserts so steel slipers are used otherwise the cam will be at the wrong angle.
Peter F.
