Loose SV tappet guides
Very quiet here. I thought I'd post a picture of today's little task.  It might assist someone. I lost compression on the 16H the other day and it turned out that the inlet tapped guide was unscrewing itself. Correcting it was easier than I expected...off with carb and exhaust pipe, then remove barrel nuts, lift barrel enough to tilt it forwards, remove tappet and guide, add a spot of Loctite for safety, reassemble. I feared I'd have to remove tank and entire top.
