I need to buy a gasket set to stop my carb leaking. Can anyone tell me what the difference is between the Amal 375 and the 376 so that I can identify which I have?
AMAL MONOBLOC 375, 376 & 389…
For a lightweight it should…
For a lightweight it should be 375 carb and it should be stamped on edge of the inlet flange.
A quick clean up with some…
A quick clean up with some gunk and there it was, 375. Thanks.
Amal 375 sizes 25/32″, 13/15″ and 7/8″
Amal 376 sizes 15/16″, 1″, 1 1/16″
Amal 389 sizes 1 1/8″, 1 5/32″, 1 3/16″
So measure the throat size on the engine side of the carb to work out which one you have.
