I haven't got a laydown b…
Your first comment is a gr…
Hi Richard - looking at th…
The pawl carrier return sp…
The pawl carrier return spring does indeed centre the assembly. Any movement of the pawl carrier will move one leg due to the small pins on the plate while the other is restrained by the return spring cover plate.
These springs are a bit prone to a greenstick fracture before they break completely. Have you had a good look at the spring ?
The other cause could perhaps be sloppy springs on the pawl itself although they'd have to be really knackered (or the ratchet worn) for it not to engage.
I fitted an NOS return spring to a Doll's Head box (I think they're the same spring) and it broke second time out. I carry a spare nowadays !
Yep. I can understand that…
Just to tidy this thread u…
Lovely day so took it for…
George. is your spring set…
George. is your spring setup like this .off a laydown box.. Baz
Attachments norton-jpg- Log in to post comments
the one in the photo has p…
the one in the photo has play in it as you are describing don't know if thats through wear though. about 2mm either way between the spring and the plate. anyway sorry for butting in i am sure Richard will know more about these gearboxes than me. just trying to help . Baz
No probs Baz - I'm gratef…
Another bit of info. The o…
I haven't got a laydown box here to run through step by step, but don't worry. Nothing that you've done under the outer cover can have any effect behind the inner cover.
This is going to be a return spring or pawl spring issue I suspect. You do have to spread the pawls to engage with the ratchet.
Do you have access to a copy of the Pearsons Edgar Franks book ? ...You ought to !![Smile](noc-chat/technical1-singles-forum//plugins/emotions/img/smiley-smile.gif)
