Can someone please give me advice on the timing of a 1930 model 18.
The bike is a real pig to start if at all.
Engine timed exactly.
Compression is great, inlet 0.006 exhauste 0.010
Newly rebuilt mag (DH Day), carb set perfect No4 slide 160 main, notch 3 on needle new lead tested, new plug (Champion D9). I even sat it in an ultrasonic tank overnight yesterday so I know its clean and not blocked.
I believe the ignition timing to be 1/2" BTDC fully advanced so set exact by DTI all I get is a "pop" and basically thats it.
Am I right at 1/2" BTDC full advance before I take a hammer to the bloody thing
Thank you John very decent…
Thank you John very decent of you to reply I will give it a try next week
It is just a case of seeing what it likes. I have had the carb off again last night and put new seals and a needle in...again! and checked the orofices clear all to be just to be sure in my mind I was not missing something.
I ordered a couple of new plugs off of "tinternet"so will put one in when they arrive.
I will time her again to your specification over the course of the week if I get time so hopefully next saturday we should be up and running.
Thank you again Sir and I will keep you posted.
On the Norton singles i'v…
Hi David,Its just me, the…
tickle it till it drips.
I had a similar prob with…
I wish I had that collecti…
Forgive me for asking the…
Forgive me for asking the obvious, but it your mag slack or tight on full advance? I got mine the wrong way around and needless to say didn't start!
Dan
Well tonight was the final…
Well tonight was the final straw!
New plug, re timed tried all advice given above and still nothing. full advance, no advance 1/2" BTDC at TDC you name it I have tried it
Kickstart has now snapped where the f**K I will find one god knows and to top it all rear stand bent beyond repair and I aint fitting any Indian shit! so enough is enough.
I have decided to cut my losses dismantle to each component and try to sell as spares to recouperate some cash...the bike has a bad vibe about it as if it is trying to tell me something. I have never had a bike not even attempt to start in over 40 years....its a peice of shit and I wish I had never bought it now.
Thanks for all your advice guys at least we tried
Before I bought it It ran…
Before I bought it It ran and did London to Brighton so I think it must be me! I am going to stick it back in the barn and forget about it for a while until I can muster some interest again.
According to one member I am racist or a member of the BNP now too as I commented on Indian made Norton bits being shit?? Sorry they are superb and we should all be fitting them and giving the NHS some trade by killing ourselves.
Some people really need to get a life and stop reading into things and help themselves and the rest of the World by actually stop thinking for a while.
Out of desperation I bough…
Out of desperation I bought some Indian control levers for an early 30's bike. The nipple holes were too small the cable, slots also, the pivots made of weak brass had to be re-made, the pivots were loose and needed shimming, the clamps were too big and the design different to the advert photo. Brilliant!, got my money back but kept the levers and re-engineered them.Lesson learnt?, No, bought some Emgo brake shoes that seem to make the bike go faster!.
Well I now believe in divi…
Well I now believe in divine intervention.
After weeks of the bike not starting I thought I would try again tonight for some strange reason.
Muttered "come on old girl or words to that effect.....
Same fuel, same tickle, same advance position, same plug etc etc and it started first time! It runs like a dream after slight carb adjusting and oil pump drip regulation (piper alpha appeared under the bike). Why did it start? I do not know as nothing has changed.
So thats it. I thank you all for your help and advice...its a good feeling knowing people are willing to help.
Oh and to say please before attempting to start!!
An ending straight out of…
An ending straight out of Hollywood
(Not Bollywood)
Nice it all ends happily ever after (cue: Sunset, disappearing rider etc,)
Carl, I have the same model for 30 years, but set my ignition with the mag fully retarded and the piston at TDC on the compression stroke. Probably not the best for outright performance but these are 85 year old bikes. Try putting a thimble full of fuel in via the plug hole, if it starts then dies you know it's a carb issue. To start normally, I give it half advance, flood a touch, don't open the throttle and kick it. I always had trouble starting mine till an old boy came over one night and proceeded to start it first kick!
Warm wishes John.
