Jubilee Wiring Diagram
I have a Jubilee Deluxe with a dubious past, it has been upgraded at some point to  12 neg earth, and has a Pazon  Ignition unit, as far as I can tell its never been run ,it was all held together with tape ,twisted wires and cable ties using  fuses, rectifiers and capacitors that should have stayed in the scrapyard,    basically in an awful condition. So my intention is to replace the whole wiring loom.
My question is, has a wiring diagram been published or available , I cant locate a decent one online.
Any advice most welcome.
Thanks   Andy
Dan:
Thanks , the OA website looks good, I will get in touch with Alan,  for my BSA there are lots of wiring diagrams online, I am surprised there doesnt seem to be similar documentation for the Jubilee.
Andy
Sorry I meant to attach this - I can email you a copy if you like. But bear in  mind you’ll probably be getting  rid of the resistor wire if you fit a new regulator/rectifier. Al can advise,
Wiring
dan
There is a Wipac diagram on my web site suitable modified for electronic ignition and Reg/Rect.
There is of course less information for the Norton on the web as it is far more an exclusive machine.
