featherbed-19-exhaust
Hi.. if i was putting a mod 19-engine in a featherbed -frame what exhaust-downpipe can i use.. remembering an es2-featherbed -exhaust downtube-will be 12mm shorter-[on the drop than a mod 19- so won't tuck in under the timing -chest cover so sits out like dogs knackers and fouls the kickstart-stroke-.. i turned up a signed photo of Freddy-Frith 1937.. i take it he was a famous Norton-man.. tommy-norton.
Hi, I have mounted a 1955 19S engine and laydown box in a 1962 slimline frame. I bought two ES2 featherbed expipes from Armour Motorproducts and cut either so they went under the timing chest and welded they together. I made the weld at one of front engine bolts and hide the weld with a clamp and stay to the engine bolt. I think this was a nice result. I have problem to attach a photo of the bike. Good luck!! Svein.
Previously richard_cornish wrote:
Hi Tom,
The model 19 engine is 1.25 inches taller than an ES2. The reason for this is because the model 19 con-rod is 8 inches between centres and the ES2 is 7 inches plus the stroke is 13mm longer, half of whichis 6.5mm. Armours list a 19s front pipe but according to their website are out of stock at the moment. This pipe also fits well on 500cc garden-gate Inters. Regards, Richard.
Hi Richard.. i am a bit confused here. my-standard es2-engine has a 7"-CONROD. my standard mod-19s engine has a 7- 1/2" CONROD. i have a spare- 8"- CONROD _+CRANK which i think would be a 16h OR BIG 4.// IF I REMEMBER WELL I TRIED THE 8 "CON-ROD-CRANKSHAFT IN A STANDARD MOD 19S-ENGINE AND THE PISTON CAME OUT THE TOP OF THE BARRELL.. ARE YOU SURE THE 19S CRANK ISN'T 7-1/2".. [ NOT SURE BUT THINK THE SIDEVALVE CONRODS ARE LONGER].. THANKS. TOMMY.
Hi Tommy,
I have just been to check the pushrod tubes on both ES2 and model 19 which are a good indicator of the difference and they are 1.25 inch longer on the 19. This is on the engines with the Wellworthy type alloy head with the iron skull. As far as I am aware all 596cc singles including OHC used con-rods with 8" centres as the length is relative to the stroke. Do you know if your engine has been modified and fitted with a shorter rod or if you have the correct piston or whether the barrel has been shortened? The only con-rod that I know of that is 7.5" and has a 2" big-end bearing is the 1930 to 39 CS1 OHC engine. Your piston should have the dished/concave top but a pre-war Big 4 is similar but has a flat top and the compression height is .25 inch higher. Yes I think you are right about side-valves including 500cc 16H and I'm fairly sure they all use 8" rods. If you have any pics you could post would be good. Regards, Richard.
Have you considered having a pipe made? Alldens in Lincolnshire do it. If you take the bike to them and explain what your after (photos, drawings etc all help) they'll make a one off.
I guess it all depends where you're based and how far you want to travel
Andy
Hi Tommy,
Hi. still think the mod 19s. has a 7- 1/2"conrod.. if an es2 has a 7" conrod.. with a 79 x100 stroke.. the mod 19s stroke is 113 mm .. 13mm is approx 1/2"inch =7" + 1/2"= 7-1/2".///.SO THE 19 COROD- HAS TO BE 13MM -LONGER THAN AN ES2-7"-ROD SURELY-IT HAS TO BE 7" +1/2" ==7-1/2".. i did have all this written down but can'f find it..[[ due to the shape of side-valve barrels i think there con-rods are longer. ????] my barrell and piston are all standard.. the cast head and alloy don't make any difference the piston crown stops at approx 7mm. from the top of liner.. the head bolts on an alloy -head pass right through the head- on a cast head they rest inside the head- about 2/3 fins up..my engine-is standard.. i'm trying to get spares of N.O.C.. but am having trouble trying to pay by pay-pal.. how do i add a photo to this page.. thanks tommy.
Hi Tommy,
The con-rod length calculation is not so straight forward as that I'm sorry to say. The ES2 length of rod is 7" which is 177.8mm, so divide this by the stroke of 100mm the ratio between the 2 is 1.778. Now if you take the 19s stroke of 113mm and times it by 1.778 you have 200.9mm which is a couple of mill short of 8". All these measurement are between the centres of big and small end holes.
The post-war model 19 (1955 onwards) was never fitted with a cast iron head as standard and the piston stopped short of the top of the barrel to reduce the compression ratio because of the extra capacity of the cylinder. All Norton singles con-rods have the length measurement cast onto the side of the rod unless it has been polished out. I still have to stand by my previous post regarding the length of the push-rod tubes unless anyone knows of any different ones. Regards, Richard.
Hi Tommy,
HI.. I RANG A MOD 19-MAN AND IT IS A 7-1/2"-CONROD FOR A MOD-19.. AND 8" FOR THE SIDE-VALVE .. NOW I NEED TO GET A 7-1/2"CONROD FOR A SPARE -19S-CRANK I HAVE.. I ALSO HAVE GIVEN UP ON A MOD 19S-EXHAUST -DOWN-PIPE + CAM SHIMS.. THANKS TOMMY.
If you have deep pockets the Bennett-cnc.co.uk website might be useful if you need a con-rod, high quality parts and truly enthusiastic family business.
Richard.
