Severed Connection
Hi, quick question,  what is the best way to remove an errant bullet (separated  from its cable) from a double connector -  it's not the end of the world I can always replace the connector, just intrigued!
Question prompted after pushing my Mk III for 3 miles last Wednesday night after the Notts. branch meeting (cause: dead battery.arising from a broken alternator wire)
Cheers. Mike
Can you not remove the bullet from the other end and push it out with a small pin punch?
You can use a small screwdriver,  but be careful not to stab yourself as the bullet gives way.
Yes a small terminal screwdriver can be used-but you will most likely find that the SNAP CONNECTOR that the bullet is stuck inside is badly corroded as well. Replace the Snap Connector as well-do yourself a favour.
Thank you both, I will replace the connector!
Al, I need to give you a call & order one of your battery status monitors!
Cheers, Mike
