Can any member tell me the overall length of the chromed pushrod tubes on the Model 19 please. I have a feeling that they are longer than ES2 but that's about it.
Previously paul_webb wrote…
For early 50s Model 19S (t…
For early 50s Model 19S (tubes visible all the way up to the rocker box) the overall length is 240mm, ES2 218mm.
Ian McD
Thanks to you both for you…
Thanks to you both for your prompt and useful replies.
Happy New Year!
Happy New Year!
yes my 19 is also 240mm. anyone out there got a spare 19-conrod.. 7- 1/2".. tommy
paul.
model 19 pushrod tubes are 240mm long.
es2 are 215mm. both measured from the[ flange were the top seal is located] and at the bottom were the bottom seal is located. my engines are 1948 and 1953.hope this helps.
tony.
