Full flow oil filter for a Dominator
I am considering fitting a full flow oil filter to my 1956 Dominator 99. Any advice as to which type and are there any associated fitting problems ? I note that there are kits available for the Commando.
George
You need to get a Dommy kit as there are differences. I need one too as I am now running on 10/30 fully synthetic.(fingers crossed).
hello now do  bear in mind that the Commando oil pump is a six start oil pump  witch runs twice as fast as a three start oil pump  so its not that a good idea to fit something thats for a later motorcycle,  you may be  better just running on a good 20-50  like Castrol LX 20/50  or Morris W20/50  or Duckhams Classic Q20/50   and leave everything as the factory intended    your anna j
I fitted a filter or Malcolm Saggers did, to my Unified Twin engine and that has the three start oil pump gears, and it work perfectly ok for me.
Yes, the oil fixed feed and return pipes measure 5/16" dia on my Dominator whereas the kits seem to be for 3/8" pipes. The inlet and outlet connections on the oil filter cap will be 3/8" dia to suit the hoses. So the search continues !
Has anybody out there found a suitable oil filter cap that has the 5/16" hose connections and also the 5/16" bore hose ?
I bought a Commando filter plate and fitted it to my '55 Model 88. The oil system is otherwise standard for the bike, ie 3-start oil pump drive. The pipe stubs on the filter plate are the same size as the pipes on the bike.  There was no issue plumbing it into the return lines.
I made a mounting plate running between the two engine-plate bolts on the right rear just in front of the rear fork pivot, with the pipe stubs pointing upwards.  The oil pipes pass over the top of the gearbox.  I would have liked the installation better if the filter itself was vertical, so that it could be filled before installation, and not leak oil on being removed.
Thanks Paul. May I ask where you got your oil filter top plate and hose from and were the plate spigots 5/16” dia ?
George
In reply to by george_arber
I bought my filter plates in the mid-late '80s.  I bought 3 of them, all the same. I'm not sure if the filter plates were from FairSpares (now called NorVil) or RGM, as I bought Norton parts from both.  The oil pipe spigots are 5/16".
One filter plate went on the Dominator 88, another on a BSA A10 Super Rocket, and the third remains unused.  The Super Rocket did many miles on high detergent 40W diesel oil and the timing side bush lasted well.
For the Dominator install, what I did was remove the old rubber oil pipes from a spare Dominator pipe assembly, and fit new rubber pipes with hose clamps.  Before fitting, I bent the return pipe a few degrees so that it passed between the timing case and the engine plate.  The rubber pipe then passed over the top of the gearbox, vertically onto the filter plate.  The return pipe exited vertically from the filter plate, curved forwards and then curved 180 degrees backwards to the oil tank union.
Before fitting the plate, I took it to a local motor factor, and got a filter to fit.  I was told that a Chrysler Alpine one was an excellent match.  My friendly expert who also worked in a Brit bike shop thought it was a better filter than they offered, as it had a by-pass valve in case of blockage, and was cheaper than theirs as well....
Apparently Norvil do one (Part number 064283) that is supposed to fit all models in various ways for about £45 plus VAT and carriage  but I have no experience of this.  There are photos (shown on Domi) on their website:
http://www.norvilmotorcycle.co.uk/064283.htm
I'd be interested in any experience that anyone has on this?
Regarding the use of synthetic oil - better for  higher temperatures, reduced temperature degradation, therefore longer life...but if  you  change  oil regularly, why would you?
Cheers,
Len
I have one from Norvil about ten years or more ago. They do a neat stainless steel bracket. But I had buy more hose...
At Ardingly there was  Dommie with the top end take off pipe taken from a home made union from before the filter. So with a clear tube, you can see that the oil is flowing quickly after an oil change. Otherwise there can be a scary delay as the cartridge is filled.
I ordered a kit for my 99 many years ago. The pipes were no use as too big,and there were no fittings for a dommy .I also was warned that the lightly pressed in steel nipples could come loose in the alloy filter housing.when hot and soak your rear tyre. That was enough for me. Back of shed.
I'd like to see how Paul threaded the hoses. I've looked at lots of Dommie installations and they mostly have the pipes looped over and under the gearbox. It all looks a bit untidy  but at least then they are inspectable. I worry about chafing through  especially where the bottom pipe passes close to the bottom of that odd little cosmetic cover between the back of the gearbox and the frame loop, and I do try to inspect quite often.
I have found all the above comments of interest and whilst I like the idea of fitting a cartridge type oil filter and appreciate it's advantages, I have decided to leave my bike as standard and use Millers 20/50 and change it regularly.
All the oil filter tops that I have researched have 3/8" dia pipe spigots suitable for a Commando
 rather than a Dommie.
George
