I have rebuilt a 1955 ES2 and have encountered a problem with the primary drive. Fitting the chain, clutch and front sprocket I'm finding the chain at the front sprocket is seriously fouling the inner chaincase. When I stripped it there was a 0.8mm washer between the sprocket and crankcase. Should there be some other spacer there?
I can't see anything on t…
The sprocket is turning an…
The sprocket is turning and the crankcase isn't (we hope !) so there definitely shouldn't be a spacer there. The situation is complicated as Norton almost produced a new inner chaincase each year.
Certainly earlier singles had a recess on the rear face of the inner which took a rubber or leather seal.
George's suggestion of the wrong engine sprocket is my suspicion too. There were at least three offsets over the years. The fact that a previous owner has fitted a spacer (which bears on what as it turns ?) suggests that there was an existing problem.
Due to the fact that aout 100,000 WD Nortons were made, most of the parts around are for them and will not be correct for your post-1948 engine.
Have you seen the late George Cohen's 'Norton Singles' website ? On the spares for sale page is a photo of three different sprockets. It is certainly worth mounting clutch and engine sprocket without the chaincase in place and putting a straight edge along the chainwheels to check alignment.
RGM have all three offsets…
RGM have all three offsets, ask if you can buy one of each and return the ones that don't fit. That's what I did, or rather was going to do but never got around to sending it back!
What confuses me is that t…
What confuses me is that the engine/drive train/g/box was working fine prior to the strip and rebuild. The sprocket is, as you guys know, on a taper therefore my confusion lies with the fact that the chain is fouling the inner case. I put a small bead of silicone between the chain case and crankcase but I don't think that would affect the tolerances.The reason for the washer that was there before baffled me to.
i had same as George there…
i had same as George there were washers fitted as per image making the chain case catch the chain
Barry
chain-case-jpg
Hi David, Have you got an…
Hi David,
Have you got an ES2 sprocket ? The large (inner) sideof the hole should measure just over 15/16ths of an inch (24mm) which is smaller than the actual main-shaft which is 1 inch so the sprocket does not go quite to the end of the taper. The sprocket used on the OHC engines is 1 and 3/32 inch to fit a 1 and 1/8th inch shaft. Just check this isn't the problem. If this isn't the reason there may be a greater problem with-in the crankcase and flywheel assembly.
Regards, Richard.
Previously Dan Field wrote…
Previously Dan Field wrote:
Any work to the clutch?
No Dan, just refitted.
If it was fine before the…
If it was fine before the strip down then the reassembly has gone wrong. Although it means removing the clutch etc I would definitely check for rogue washers behind the inner casing. That's what caught me out. If the drive sprocket is correctly fitted then the only other thing (apart from a new oversized chain?) is the position of the chaincase, hence my comment. George
I can't see anything on the parts list, David. Have you got the correct off-set on the drive sprocket? Is there a washer between the inner chain-case and the crankcase anywhere? There shouldn't be. I made this error on my '55 ES2. George
