Basket Case
Recently purchased a basket case Jubilee and in the process of building it? I have 3 barrels stamped 20749RH, 20747LH, and 20717?
Also 3 heads stamped X20717RH, stamped AM X20715LH also stamped AM and 22941RH
Which are the correct corresponding numbers for a Jubilee and what do i have please????
Kay
Kay:
You have placed your inquiry in the singles section. It should have been placed in the "Light Twins" section. If you re-send perhaps you will get more responses.
