Banjo bolt availability
Has the situation changed since the thread on the subject a couple of years go? I see Goodridge Banjo Bolts make a range so wondered what is the thread size/pitch on the original C62 part. Thanks for any help. George
Ooops. Sorry. The part no. is C3/700. That makes it a bit easier to find! Looks like they are now available. George
George, I couldn't find one anywhere. Had to get a mate to make one. Hope the spares situation has improved since?
Norvil has it listed as available, Neil. Also an outfit in America. But pricey at around £20 though. If I can undo the one I have without damage I'll not need one! George
Cut a slot in the banjo bolt with the Dremel. Filed down the right angle short part of a right angle tyre lever and used it as a right angle screw driver. Success! Bolt undone. But at least I now know I can buy a replacement if needed. George
