Plunger lubrication quandary, â51 ES2
My complete rebuild would be on schedule if new âissuesâ did not crop up every week !#!&!!.
Iâve dismantled my Plungers; Soaked off the rust and decades of old grease stuck in the coils.
I notice that the grease nipple in the alloy rear fork-end lubricates only the bearer rod; the spiral groove along the length of the rod allows the grease to lube the roughly 9â of rod-travel on the fork-end unit as the springs compress and rebound.
My question; how should I treat the springs and spring cavity ?
The spring covers are not watertight/airtight, so rain and/or condensation will enter the spring cavity.
If I load them up with a cup or two of grease, then I fear that the water that gets in will be trapped and not find its way out the bottom.
My two original period manuals donât mention oiling the springsâ?only the bearing rod.
The implication to me is that this cavity was initially empty from the factory with presumably some grease smeared on both ends of the springs where they bear on the covers. Any lumps of ancient grease I found had oozed out of exposed part of the bearing rod at the top and bottom of the cavityâ? as previous owners enthusiastically pumped grease into the nipple.
Am I correct in my thinking here ?
I am contemplating coating the inside of the covers and the springs with rust-paint, then spraying them with ACF-50 anti-corrosion spray (which works wonders on my old bikes). This would rust proof the springs and insides of the covers and act as a lubricant since the springs always seen to rub slightly on one side or the other of the covers depending on how I orient them.
Does this seem sensible?
Does anybody have and advice or an alternative approach?
I have put a couple thousand miles on the bike so far and I am very pleased with the way the Plungers feel and handle. That little bit of extra play compared to a rigid frame makes all the difference for me.
Grant MacNeill, Toronto
51 ES2, 51 R51/3, 62 R27
By the way, if you have not tried the new Paul Goff LED headlight bulbâ?I highly recommend: very bright, low draw and seems to last forever
Hey Grant,
I'm a real fan of using sticky chain lube for this purpose. I've used it on unplated fork tubes up inside the headlight ears that normally get rusted and then impossible to dismantle. Came apart like a dream years later.
