Hi all,
Can anyone tell me what the internal washers are made from in the fuel taps on my 1955 ES2. These are the washers that the push-pull mechanism slides across to line up or close the holes in them. They look like leather but difficult to tell because now are mostly dust. I'm assuming I will have to make some, I doubt I can buy some.
Many thanks,
Alan
See: 36A_PT/CORK/F in NOC…
Alan: Can you post a photo…
Alan:
Can you post a photo of the fuel taps in question?
Over the years it is possible that a previous owner has changed the taps from what was originally supplied.
You could have the round bodied Ewarts type which use cylindrical pieces of cork or something else.
When you fit the new corks…
When you fit the new corks, immerse them in boiling water for a few minutes. This makes them very soft and pliable.
For the round bodied Ewarts taps, I found it was easiest to cut the cork longitudinally on one side to avoid forcing it over the locating lip.
Previously Michael Rettie…
Previously Michael Rettie wrote:
See: 36A_PT/CORK/F in NOC Shop
Thank you MIchael. Will do.
Previously michael_sulliva…
Previously michael_sullivan wrote:
Alan:
Thank you Mike. Hope I've done this correctly and it reaches you.
Alan
img_0198-copy-jpg
Previously ian_soady wrote…
Thank you. I'm learning so much!
Alan
