Has anyone any experience of the Craven "W" rack on a swinging arm pre-featherbed ES2?Cheers, George
I have one on mine. It loo…
Thanks for the response, I…
Thanks for the response, Ian. I was rather hoping that Craven supply everything needed to fit it. I don't have tremendous facilities for making stuff. George
I've taken a better pictu…
I've taken a better picture. Craven may should do some sort of fittings. Carrier isn't much good without them.
Ian
dscf3663-half-size-jpg
Hi George I have a Craven…
Hi George
I have a Craven rack and top box in the loft that I took off a Commandoabout 15 years ago. If you are interested I could go up and take a few photos and if you think it would be of use to youI'm sure we could come to some sort of agreement.
If you are within striking distance of the Stafford area you would be welcome to come and have a look.
Bob
I'm a bit concerned that…
I'm a bit concerned that the whole of any load on the carrier would appear to be routed through the mudguard and its mountings given that there aren't any stays to (say) somewhere near the bottom of the rear subframe.
Your concern is justified.…
Your concern is justified. Rear guards on these models have been known to fail just above the lower mounting bolts (behind the gearbox). Load on the carrier stresses the guard in one direction, lifting the bike onto the centre stand stresses it in the other direction. It might be OK for waterproofs and a light lunch but a rack that size will be also be used for heavier stuff. I think Craven recommend bracing to the pillion footrest mounts.
Ian McD
there should be thick rein…
there should be thick reinforcing plates welded inside the mudguard that run around each side of the mudguard edge to help support the weight.
Barry
Mine doesn't have the hin…
Mine doesn't have the hinged mudguard, which makes it stronger, and heaviest thing I carry is a U lock and waterproofs. So far so good.
Ian
the rack in the photos loo…
the rack in the photos looks well made. it looks hefty enough to put anything on.
Barry
Thanks guys. Good response…
Thanks guys. Good responses. Ian G - do you grab the rack to get the bike onto the c/stand? Bob J - I'm halfway down Cornwall but thanks for your kind offer. Not sure anyway whether a Commando rack would fit an ES2 without some massive fettling. Ian McD - yes, I think I've heard that a supporting brace is needed but it must look a bit naff. It's a long way from the rack to the rear pegs. I'm beginning to wonder whether the negatives outweigh the positives. G
No I don't use the rack t…
No I don't use the rack to pull it on to it's centre stand. Here's my method.
Left hand on left handle bar. Right hand holding the bar on left side of rear mudguard. Push stand down with right foot and push right side of lower right leg against front of pillion footrest. Then at the same time press leg backwards against pillion rest while toe holds stand in place and lift with right hand. Mine goes onto the stand fairly easily then.
Ian
It's a bit off-topic but…
It's a bit off-topic but I could argue that it's my thread........but because I started with rear wheel stands I tend to put my left foot behind the centre stand and both hands on the rear mudguard bar then heave and lift. Not very efficient and hurts my back! George
Blimey George, how often d…
Blimey George, how often do these threads stay on topic?
Your centre stand method does sound like a recipe for a bad back so can see why you want a reliable side stand.
Ian
There is a place called Cl…
There is a place called Classic bike racks who make racks
in stainless steel. Nice welding but all use bad methods of mounting unless you carry something light. Craven use to supply supports to triagulate to the rear foot rests if any weight was intended to be carried.
I sympathise on the lifting, I have to remove one pannier to lift my Commando on to center stand. On bad days it the garage I use the electric hoist to lift it on to stand or on to the bike lift.
On the 99 I use the Craven…
On the 99 I use the Craven carrier to lift the back of the bike if it needs moving,no problem, but then it does not have a "bendy frame"!.
Have a look at the craven…
Have a look at the craven site. The L rack with pannier support is the best system.
Thanks Chris. I've seen t…
Thanks Chris. I've seen that one. Not sure how well it fits and ES2?
I have one on mine. It looks right. I bought it used off Ebay before Craven started making them again. Made my own fittings for it.
This is a picture before I painted the brackets. Not the greatest picture.
carrier-brackets-jpg
