slipping clutch and no way of getting slack at clutch lever. help please!
it's a lay down gearbox and the adjuster on the gearbox is screwed right in
too many clutch plates?
Attachments p1010008-7-jpgReferring to your second p…
Referring to your second picture. The clutch lever is clamped to the worm shaft (2) by the nut (1). The way to adjust it is to undo nut (1) so the clutch arm is free and use a large screwdriver in the slot of the worm shaft (2) to turn it and get some play in the clutch pushrod. Then clamp the arm at about 45 degrees down from the horizontal. You should then have a working clutch.
sorry about that John i di…
sorry about that John i did the photo then i had to phone and growl at my insurance company .its adjusted as Ian describes
Barry
many thanks Ian and Barry,…
many thanks Ian and Barry, i'll give that a go this afternoon and keep you informed!
When I had this problem, J…
brilliant, sorted, and so…
brilliant, sorted, and so simple!
Attachments image1-jpg1-copy-jpg
