Hi All.
I have a general question regarding upgrading the less than perfect headlight brightness to H4 halogen. My 1960 Dommie currently has the bog standard BPF fitting and uses therather whimpish 45/40W incandescentLucas bulb. I have beentrawling throughnumerous sites and have foundSRM in Aberystwyth have a Halogen 45/40WBPF bulb.As H4s give out quite a bit of heat would the original headlight unit be suitable or would I have to replace it. Any thoughts?
Cheers in advance
John Sunderland
LED is the way to go, high…
Paul Goff has a wide choic…
Paul Goff has a wide choice of alternative brighter bulbs.
http://www.norbsa02.freeuk.com/goffybulbs.htm
Ian
The H4 bulb has to fit int…
Got to disagree with John…
Got to disagree with John H. In my experience LED headlights are great until the sun goes down. They light up everything except the stretch of road in front of you. Disappointing...
The H4 reflector and bulb combination is good.
The old 50/40W BPF isn't bad either provided you provide a separate earth lead back to the battery, advice which applies to any lighting setup.
John, I have a new old sto…
John, I have a new old stock Wipac Quadoptic with a sidelight fitting as well, I've got a spare QH H4 55/60w bulb as well £20 plus p&p if you want it. 07751 307963
Hello Well there are some…
Hello Well there are some Pre-focus fitting. LED ones out now price £8 each yours anna j
Have a look here: http://w…
Have a look here: http://www.nortonownersclub.org/noc-chat/general/770632805
Fritz
I have just returned fromD…
I have just returned fromDublin this morning and there was a lorryunloading at some roadworks on the motorway. He had six spot lights on top of the cab, six spot lights across the front bumper, two headlights, two fog lights, plus his hazard lights - all fully lit up. He certainly attracted attention-but I suppose that was the idea. Certainly nothing wrong with his alternator.
Sorry this isn't of much help but I suppose most people just use their headlight to warn of their presence rather than illuminate the road during the hours of darkness.
I went to Paul's site &am…
I went to Paul's site & bought my halogen headlamp bulb, plug & play, no mods, very happy, LED on everything else including the speedometer bulb!
LED is the way to go, higher light output, lower heat and watts comsumed.
