What rating for kill switch?
Hi folksI'm intending to add a hidden kill switch to the ignition circuit on my Dommi and think I have found the ideal switch for the job. It is certainly the right size physically and is both weather and vibration proof.It is rated as follows and I would be grateful for input from those in the know as to whether or not it is up to spec as I admit my understanding of electronics is limited.Max. current/voltage rating with resistive load: 400 mA 32 VAC - 100 mA 48 VDCMuch obliged as always,J.
Does not sound as if enough current capacity for a coil system.Does your bike have points? .
Hi RobertIt does have points. A colleague suggested today 2-3amp rating possibly. Does that sound about right?
Previously jason_jordan wrote:
Hi Robert It does have points. A colleague suggested today 2-3amp rating possibly. Does that sound about right?
Not quite, coil ignition takes 2-3 Amps but you always need a but of safety/headroom so I would suggest that you have at least a 5Amp toggle switch as your kill switch with some decent connectors to it.
