Can anyone recommend a dealer who can provide a standard good quality wiring loom for a late 1964 Navigator? The Lucas (part no WW19215) one that Norvil sell isn't correct in the position of the horn, coil or contact breaker wires and it only has one coil and contact breaker wire! I don't want to convert to 12v electrics and want to keep it as original as possible.
Have a word with Al Osborn…
Thanks Dan, I have looked…
Thanks Dan, I have looked at his kits on his web site which are certainly an option but I was hoping to track down a ready made up one with a fabric cover like the original.
Nick
Hello Nick, Someone was ad…
Hello Nick,
Someone was advertising new wiring looms for the Jubilee/Navigator fairly recently on Ebay. They seemed to do two versions -one had the proper Wipac switch connectors and another without - at different prices. It was an English address. I think it said they were made to order and not a stock item. There was some comment about the resistor wire not being available and to use something else to compensate. I know nothing more about them so can't say if they are correct or not. I am fairly certain that they were cloth covered.
You do surprise me with your comments on the loom from Norvil as it would seem strange to have new looms made which are not correct. The wiring loom was Wipac - not Lucas. They may be for a Bantam with some modifications. I do remember Bantam John telling me (ages ago) that he had the correct loom for the Jubilee and was very sarcastic that some people thought it was the same as the Bantam but with some extra connectors for the ammeter -it isn't if you want to be correct.
Patrick
Search Ebay under Norton N…
Search Ebay under Norton Navigator wiring harness. Seller is 5* Flea Market at Burnley. His ad gives the impression that he knows what he is talkng about.
I see ads as well for "new genuine Lucas" wiring looms for Jubilee etc from other sources. A bit like saying a new genuine diesel engine for a Jubilee.
I need a new wiring loom f…
I need a new wiring loom for my 1964 Jubilee; it does not have a loom at the moment. I am thinking about buying one on EBay but all you have is a picture to go on. I will be doing the 12V conversion and I know some say it is not worth buying a loom if you do the conversion but I would rather start with a loom and adapt it.
If anyone has bought a light twin loom with Wipac sockets from EBay I should welcome their comments on its suitability and quality.
Patrick, thanks for that,…
Patrick, thanks for that, I saw the advert too and it looks promising - I have emailed 5*flea market asking for them to contact me to discuss spec and possible ordering and let you know how it goes!
Dennis, I'm keeping mine 6 v at the moment so will be asking for a standard loom. I will let you know as I learn more.
Nick
Bear in mind, that the ori…
Bear in mind, that the original looms had a resistance wire built in - in its own asbestos? sheath. The resistance wire was important if you are sticking with 6volts, as it controlled the charging. Modern looms assume 12v - and that you will be using a regulator of some sort - Zenor Diode, PowerBox, etc.
Thanks Andy, good advice -…
Thanks Andy, good advice - luckily I picked up on that from a post some time ago so haven't ordered one yet until I have spoken to them. From reading the specification on their ebay ad the manufacturer is aware of this saying that the resistance wires are no longer available so they provide a 'ceramic resistor' which attaches to the frame and does the same job. I will report back when I know more! By the way you will remember me asking about ignition timing because my Navigator was reluctant to pull in top - when I stripped the primary side down to rebuild the clutch and replace the oil seals I discovered the drive sprocket was 24 teeth - no wonder! I replaced it with an original 19 tooth sprocket and it is transformed (no surprise!) and pulls very happily up to its quoted top speed......although it is revving very hard at that speed! I am wishing I had been brave enough to risk the 20 tooth that you use.
Nick
Hi all, I've just spoken…
Hi all, I've just spoken to Bill from 5*Ebay and purchased on of his complete Navigator wiring harnesses,. £75 or so including postage etc which should arrive late next week. It comes complete with Wipac plugs and all the ancillary looms, and includes a solid state resistor which replaces the 'resistance wire' which is no longer available. This attaches to the frame via stainless steel tie-wraps because it runs slightly hot as the original wire does. As a one off this month he is including a modern solid state rectifier free so it will be interesting to see how this works out. If you are interested the harness is listed under No 253536705738 or search on Norton Navigator and Jubilee wiring harness with plugs. Having chatted to him on the phone (01282721720) he certainly seems to know what he is talking about when it comes to lightweights and their electrical foibles having only recently sold his Navigator. I will report back once it has arrived and I have had the joyous task of fitting it!
Nick
With regard the 'standard…
With regard the 'standard' loom, NOS is always suspect as after some 50 years or so even if the loom has never been used there is still some tarnishing of the wires and connectors so be aware. New looms might be ok but as you seem to be aware the 6V needs the charge reduction resistor (used when the lights are all off) a new style ceramic one of 10 Watts or so should be ok but I have seen several dreadful attempts at this resistor. Again before keeping it original 6V please check out the words re 12V and electronic ignition on my web site. 6V (if you must) then an original loom might be ok but 12V and electronic ignition and a fresh loom/start is needed.
I have 6v navigator wiring…
I have 6v navigator wiring loom with resistance wire and points on my bike, but it constantly needs watching. Everything works as it should but the output from the alternater has to match the load taken off. Bulb wattage needs to be tailored so that the ammeter hovers between slight charge and discharge.
6 volts is the problem that most affects reliability because current consumption is twice that of 12volt,. any intermttant fault in the switches or bulb holders or bullet connectors messes up the system ( usually on the move) , which can be hard to trace back in the workshop. 12volt and electronic ignition wil happen when I get fed up with my 6volt system.
Ithought the resistance wire was only used on side lights ? ?
Alan, thanks for all your…
Alan, thanks for all your sage advice and fear not I have read your excellent missive on 12v conversion and understand this will be the way forward when I finally do a full restoration on the bike. However, it is always a dilemma when presented with a relatively low mileage bike in totally original condition which is generally running really well despite the original electrical weaknesses. My alternator is working well as is the rectifier with the battery holding charge. The timing is spot on and the engine is running smoothly and is well up to form when it comes to performance. The only problem with the loom is the inevitable degradation round the steering head with several broken and badly repaired wires. Given the limited amount of night driving I do, the headlight being just adequate and the need to build a bespoke 12v loom and cost of the electronic ignition conversion on balance I have decided to stick with 6v until the total rebuild. There is more than a hint of sad masochistic 'original' obsession about this for me but my Lightweight ownership has always been like that!
Graham - I suspect we share the same view! Interestingly running with just the side light and normal ignition selected my Navigator seems to keep the ammeter comfortably on the slight charge side of the line when cruising with no sign of under or over charging on a 50 mile run. Is that your experience?
Nick
Hi Nick, I totally agree w…
Hi Nick,
I totally agree with your philosophy about keeping things original as far as is reasonably possible Both my De Luxe Jubilee and De Luxe Navigator run very satisfactorily with points ignition and 6V systems. They are a bit fiddly at times but you can do roadside repairs (if needed) quite easily. If the electronic system packs in that means a trailer home. Anyway why should someone buy an old machine in the first place if they immediately update all the systems by changing the old drum and cable brakes to hydraulic triple discs, fitting modern electronic ignition and charging, etc etc. Surely the intention is to remember the 'joys' of yesterday riding/driving.
I think that the resistance wire only comes into play when the ignition is On normal and all lights are off. My ammeter stays on the plus side again without any signs of overcharging.
We have just returned home in the 1958 Morris Isis after a 20 odd mile run to a local show; points ignition, drum brakes, standard Lucas dynamo, - no power steering, no servo brakes,no electric windows, no sat nav, no heated seats but it drove there and back absolutely faultlessly; just like it would have done when I was a learner driving a Morris Isis on L plates.
Patrick
Kindred spirits Patrick, m…
Kindred spirits Patrick, my unmodified Mk2 Vitesse convertible I first restored 22 years ago is still running as smooth as silk on its standard points ignition and without a brake servo or power steering! I have to confess to an alternator though, I just couldn't find a decent dynamo back then although they are available now - I'm just too mean to spend the money until the alternator gives up the ghost!
Nick
Nick, I could not wait as…
Nick,
I could not wait as my Jubilee is nearing completion so I ordered a loom off EBay from Bill. It arrived today and looks pretty good with soldered bullet connectors and Wipac sockets.
I too have now decided to get the engine running on a 6v system and then think about converting to 12v and electronic ignition. It is more expensive to go down that route but I need to see the engine running before I invest yet more money on a bike that I bought in bits.
Just to get this right. Th…
Just to get this right. The Lucas alternators RM15 -RM19 all have three wires out. This gives 1/3 output BLK/GRN and 2/3 output GRN/YLW. But the WIPAc as fitted to the Lightweights although having three wires have 50/50 between the two out put wires (YLW and ORN I think) this means that on ignition only the Wipac tends to want to over charge the battery so it incorporates this resistor in the loom. On side lights we need a little more output so this resistor is removed (By lights switch.) So the result of having no resistor is slight over charging of the battery when on ignition only. You can offset this by riding with the side lights on.
Alan, thank you for that r…
Alan, thank you for that really helpful advice, very useful to know exactly how the alternator works so we can manage the charging rate appropriately. I have fitted Bill's wiring harness which certainly seems of a high standard and comes with a copy of the original wiring diagram and all the leads tagged so even the most inexperienced can fit it easily. My only criticism is the resistor which isn't really robust enough for the rough and tumble of Lightweight life so I have sourced a better one which I plan to fit this weekend. I will provide feed back once I have given it a thorough test drive! One question, I can find brand new Lucas RM19 6v, three wire, encapsulated alternators stators for sale on line. Will they fit my Navigator and are they compatible with the Wipac rotor? Nick
Previously Alan Osborn wro…
How would the lightweight wiring loom or switch connections need to be refigured if going from wipac to lucas alternator ?? One small change like this messes the balance.GRAHAM
Well the new loom is worki…
Well the new loom is working as advertised although I have replaced the ceramic resistor with a more robust ally cased one with cooling fins which cost all of £2.75 on ebay! Bill supplies an identical rectifier to the one advertised in the Club shop, luckily I noted a previous thread which highlighted the need to run an earthing lead to the fourth terminal marked +. A 50 mile test run today with the headlight on and off proved the battery is charging nicely both with and without the resister in circuit. It may have been the weather but the Navigator was running really well, pulling comfortably to 70 briefly on the motorway with more to come but in deference to her age I certainly don't intend to push her! Stopped to take a quick photo in a local bluebell wood which I've attached. Not looking too bad for a 1964 bike that has never been restored and is in its original paint!
navigator-and-bluebells-jpg
That is looking good. That…
That is looking good. That late blue colour certainly looks good.
Do we call 'her' Bluebelle?
My wife thinks that 'Blue…
My wife thinks that 'Bluebelle' is a most appropriate name Patrick, I'm not so sure it sums up some of her Lightweight foibles though! However, every sign so far is the wiring harness and modern rectifier from Bill is good value for money. I'm not convinced that the ceramic resistor he supplies is robust enough for the job, I will see how the aluminium encased one I sourced fro ebay fares and report back. Next job is to fix the slightly leaking petrol tap - deep joy!
Nicholas, Would you please…
Nicholas,
Would you please let me know which 'finned resistor' you bought on EBay. I can't seem to identify the right one.
Many thanks,
Dennis
Dennis, I searched on 'al…
Dennis,
I searched on 'aluminium clad power resistors' and came up with thousands of variations! I struggled to find a 10W 3.9 Ohm resistor from the UK although found some from China / Hong Kong. I am no electronics expert but assumed that my ancient alternator is probably not producing quite as much power as it should so I chose a 10W 3.3 Ohm resistor from Phi Sigma Electronics (photo attached) - at a cost of £2.39! This is working although it gets very hot with just IGN selected so I have used a Jubilee clip to hold it to the frame as a heat sink - I suggest you check very carefully that it isn't overheating and a fire hazard if you try one! Bill from 5*Fleabay recommends strapping his ceramic resistor to the frame with a metal tie-wrap which got just as hot! I have found a 50w 3.9 Ohm resistor from China and ordered one as a second option but not due till 23 May so don't know if it will be up to the job till then. Hope this helps! Nick
resistor-jpg
Nick, I bought two new a W…
Nick, I bought two new a Wipac-pattern switches to go with the new wiring loom but I took them both out of the boxes before noting which one is the ignition and which is the light switch! Schoolboy error. They have no markings on them so I can't tell which is which. Do you know if they are connected differently internally or is the only difference the letters on each knob?
The switches are Wipac numbers SO 781 and 781.
I have a multi-meter so it might be a case of wiring up the bike and checking each switch position if they do switch differently.
Dennis
Hi Dennis, The switches ar…
Hi Dennis,
The switches are interchangeable - the difference is only the knob.
Good to know coz I almost…
Good to know coz I almost did the same thing when mine arrived!
Al Oz recommends soldering…
Al Oz recommends soldering short wires with a bullet connector at the end, to the switch connectors, it gives a more reliable connection, the connectors that came with my loom from the club certainly donât fit the switch well but are working for now.
dan
Phew! That's a relief. Ju…
Just got to work out how to fit the combined rectifier/regulator now.
Previously Nick Clarke wro…
Previously Nick Clarke wrote:
Dennis,
Another option is:-
https://uk.rs-online.com/web/p/panel-mount-fixed-resistors/1074125/
regards
Tony, Thanks. The one I bo…
Tony,
Thanks. The one I bought looks very like the one you suggest. I am loath to scrape powder coat off the frame but I assume the resistor needs a heat sink so good contact with bare metal may be required and perhaps some heat sink compound. Would copper grease be a viable alternative to heat sink compound which is very expensive; I have copper grease
Dennis,
Your idea that the alternator is tired and giving lower output is reasonable but your guess to go for a lower resistor is the wrong way, if you want to 'waste' less electricity then you need a higher resistor BUT at these values and charge rates it will make insignificant difference.
I can supply a resistor of 3.9ohms but I charge £5 because I have to send it to you (and maybe make a profit)
Thanks Al, the expert advi…
Thanks Al, the expert advice is a huge help in understanding how to find solutions.
As for the new loom, rectifier and ammeter they are all working nicely now. I used the Navigator as transport to a number of work meetings round Somerset yesterday covering 100 miles. I varied no lights, side lights and headlight during the trip and the bike ran perfectly, showing a slight charge throughout and keeping the battery nicely charged. Deeply worrying is it didn't leak any oil or petrol - and yes I did check there was plenty in the tanks, gearbox and primary side! There is no sign of overheating round the resistor although I'm not happy with the solution of using a jubilee clip to hold it against the frame.
The 50w 3.9 Ohm resistor arrived yesterday (picture attached) and looks very similar if not identical to the one you posted Tony. When I have a moment I am going to make up a metal bracket to bolt to the frame to act as a heat sink and mounting. I will report back once the job is complete.
Nick
resistor-3-9-ohm-jpg
It lives! Having fixed the…
It lives!
Having fixed the new wiring harness to my Jubilee I am at least getting a good spark at both cylinders. I almost got the plug leads right first time I was only 100% out
Have a word with Al Osborne, heâll sell you a kit, heâs the clubâs electrical expert, his website is AO services I think.
Dan
