16H tank bolts
Can any one tell me the thread size of the 4 bolts that hold the tank on
many thanks Ian
Adding to that, the bolts are 'shoulder bolts' where they can only be screwed in up to the larger diameter shoulder. This is to stop the bolt threaded end being wound uptoo far thereby piecing the tank bottom.
Paul.
Previously ian_burgess wrote:
Can any one tell me the thread size of the 4 bolts that hold the tank on I should added to ON A BIG 4
many thanks Ian
many thanks Ian
So the shank length is such that the rubbers are squeezed the right amount above and below the tank bracket plate when the bolt is tightened hard up.
Incidentally -my prewar 16H bolts are identical to those on my slimline Dommie. So they should be available from usual suppliers.
