Battery platform
hi does anyone out there have a photograph and dimensions of a 1955 international battery - oil tank platform ( the underside ) please .
cheers Ian
I know of a very original featherbed International, and can get in touch with the owner. He may be able to help
I would like to get info on the rear numberplate mount used on featherbed Inters and pre-'55 Dominators. Does anyone make them?
Hi Paul did you get the message and photo I sent something going wrong at my end as some posts are coming up and some not.
G'day Ian, I have made the battery platform for my '57 Inter. I will look for the sketch tonight and hopefully send it. I obtained the rear guard, front guard and rear number plate bracket from Fred Williams. It is best to try and contact him by phone and his number can be found by searching the club's site. Peter
Hello Peter the sketch would be most useful thank you. Ive spoken to Fred last week and heâs going to help me out with a few things. Ive got the mudguard but havenât had them blasted yet to see what there like. I do need the brackets for under the battery platform but didnât ask about them . Thanks for the reply Ian
I hopefully have attached the sketch, the greasy figure marks are extras. My bike has alloy gear box and engine plates, so you will need to check the spacing. I made mine to this sketch and all fitted.
Cheers,
oil-tank-battery-platform-pdf
Hi peter thanks for your drawing its got everything I need on that. Good to government paper has been put to good use for a change .
cheers Ian
